Question about Toro "Toro" Super Blower/Vac
I have a Toro Super Blower Model 51591, and need a replacement power cord. None of the online catalogs show this as being for sale. Can you recommend an alternate source?
You probably won't find one (at least I haven't). But if your cord was damaged in the same way as mine (at the base, where it goes into the unit), I will be happy to share with you DIY fix that worked for me. Email to radist2000@yahoo.com.
Posted on Apr 01, 2010
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
How do replace the impeller on a toro 51591 super blower vac?
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Where can I find a reset button that went bad on my model #51591 Toro Super Blower. Toro direct told me they don't have the part any longer. Not happy about this it's just a stupid little button that can...
I also had problems getting my toro 51591 to work. I too discover the safety/kill switch. i used a screwdriver to push it in the hole and activate the machine again. it started right up. I too was going to(and am) find something to put in the hole(like a screw/nail to override and keep the machine from stopping again.it would be nice if they would tell about these safety items. like that they exist ,& where they are located, and how they work. so first try to just rest it by using the screwdriver to push the rest button. it is located on the bottom . it is just a small rectangle where the plastic part is suppose to fit . mine showed a white color filler. plastic part probably broke off and is now too short. so need to do the nail/screw trick to fix it. with duct tape. good luck
Dec 02, 2010 | Toro "Toro" Super Blower/Vac
Need impeller # 100-9068
Here you go. $11.99 on EBAY right now:
http://cgi.ebay.com/100-9068-Toro-Impeller-for-51591-51573-51552-Fast-Ship_W0QQitemZ370301014626QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5637a91262
Dec 29, 2009 | Toro "Toro" Super Blower/Vac
Toro Blower..No power. Like a blown fuse. Does it have a fuse?
I have the Toro 51591 model. Yesterday, mine did the same as yours. I opened up the case and found that a small cylinder had broken off of the switch. So it could be that your switch is the problem. I have been unable so far to find a replacement anywhere.
You should consider using your warranty.
Dec 12, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Toro blower model 51591 electrical prong melted. help!
The answer is wrong. This model and other Toro blowers with the plug built into the body (as opposed to the new design with plug on cord) has this problem when the plug does not completely mate with the cord. This happened to mine too. Unfortunately Toro does not provide a replacement part. HOwever, perhaps the new designed cord will fit as a replacement, but I am unsure of this. When my plug melts completely I will try that.
Dec 22, 2008 | Toro Blowers Rake and Vac - Electric...
Toro "Toro" Super Blower/Vac Logo
579 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
