Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
2 monitors down in 2 days! Planned Obsolescence?
I purchased 2 L1975NW 19" Widescreen monitors at the same time, and have used them together for a little more than 2 years (the length of the service plan). 2 days ago one of the monitors quit working, at first when I would turn it off/on again there would be a perfect picture for a second then black. I can't get anything but black screen. Now the second monitor is having the same problem! They have both been plugged into a UPS for their entire life so I don't think power surges where to blame. Should I just bite the bullet and buy new monitors? Or is there a simple solution? I find it very strange that they quit working within days of each other. Planned Obsolescence?
  • billy248 Jul 21, 2009
    I did test the computer with other monitors (works fine), and tested the both of the broken monitors on three other computer (no joy)
  • 1,684 Answers
We have a free repair guide posted on our web site at:
www.ccl-la.com/badcaps.htm It gives step by step repair procedures for the Westinghouse L1975NW monitor. The problem is caused by a bad power supply and it is a simple fix to get the unit back running.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Nov 08, 2009
  • 400 Answers
It could be a computer problem
The only way would be to test the computer on another monitor and the current monitors on another computer.
Then you will see which has failed.
Posted on Jul 16, 2009
What run capacitor will work on dayton fan motor model # 2LY97A
Over heating and like most new product these days throwaway planned obsolescence and made to fail
Feb 10, 2015 | Dayton Dryers
Polar ft40 watch doesnt work. I have replaced the battery and nothing happens.
This heart rate monitor has a generic flaw with the sensor. The touch sensor fails after a few months of use. It is not a battery issue. Return to where you purchased it. Buy another brand. All of the drug stores carry this watch which has an abnormal return rate. The sensor fails after a few months while the watch function is fine. Seems like planned obsolescence.
Sep 07, 2011 | Polar Electro Polar FT40F heart rate...
Image blinks off after about 1 second after being powered up. Cut the power off at monitor, then turn back on and it repeats. Full image from computer shows up for about 1 second then disappears. The...
Please look here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 13, 2010 | Westinghouse L1975NW Monitor
The color is incorrect on my L1975NW (Westinghouse) widescreen
Try hooking it up to other PC to see if it does the same thing.
Try another VGA cable.
If none of above change the symptom then open it up and inspect the caps in the power supply, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Computers & Internet
I have a E machines 19" widescreen flat panel computer monitor that is only 6 months old. For the last few days when I power up my computer, the monitor comes on for 1 or 2 seconds then flickers and goes...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jan 04, 2010 | E-Machines 19" Widescreen Flat Panel TFT...
My samsung 19 widescreen got white screen after 2 years can I fix this some how? / Johan
Hi! using analog it seems to work for now but sometimes it blinkes white on the screen,it seems to work better when I have had the screen on, for some hours then it seems to work fine.. But I dont know for how long..
samsung 19 wide.
/ Johan
Oct 21, 2009 | Samsung T190 19" Widescreen LCD Monitor
VG4 mode on Insignia 19" widescreen LCD wont accept computer
go to your control panel of your computer (using a different monitor obviously) and change your screen resolution to 640x480, 800x600, 1024x768, or 1440x900. any of those resolutions should work. also go to advanced and make sure it is set at 60 herz.
Feb 25, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
New widescreen Monitor
You should download latest graphic card drivers from this link below
http://ati.amd.com/support/driver.html
Feb 27, 2008 | Westinghouse L1975NW Monitor
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
238 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
