Question about Boating
I have lowrance 337 c gps combo, I have a lund baron i/o aluminun boat. When the boat is running i get alot of interference on the screen. I tried running the power cord for the graph direct to the starting battery, still get interference. IT would be nice to be able to use the unit under power searching for structure and fish, instead of using the trolling motor.
  • 86 Answers
You can use a thru-hull transducer but a transom mount transducer will always interference with all of that water and alot of air bubbles moving under it at high speeds.
Posted on Aug 02, 2009
Lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Jul 09, 2008 | Lowrance LMS-337CDF GPS Receiver
The depth finder on my elite 5 Lowrance blinks if I go over 14 mph. And the screen gets very hot after a few minutes of run time?
Hey Robert,
the blinking is usually the result of the transducer losing contact with the water..
As far as the screen getting hot.. that is not good.. do you have this unit mounted in dash? It needs some ~cooling.. just some airflow..
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Aug 28, 2016 | Lowrance Elite 5 Color SonarGPS Combo
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Problem with interference lowrance x25fishfinder
Transducer will stop getting readings if it gets air under it. If it's lower surface is too much above or below the bottom of your boat, this can happen.
Apr 05, 2009 | Boating
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Boating Logo
166 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
