I bought a used washing machine yesterday from a friend. We installed it together and I noticed sudy water leaking from the front and back of the bottom of the washer. He said he hadnt used them for a while because he didnt have hook ups at the apartment he had been living in, but worked perfectly beforehand. His dad bought them used for him and he remembered that happening at first too but that it just sort of stopped. I asked my mom and she said that she had heard the same thing about a water heater last week that she was installing in her home. Is it true that the hoses expand or something to that effect? Thanks
    President:
  • 1,776 Answers
If it set for a long period of time, then the main tub seal may have gotten dried out. Storage is hard on items like seals and belts. It may swell some and seal itself with some use, but there is no guarantee that it will. Hope this helped.
Posted on Jul 16, 2009
Leaking MAH2400AW washing machine
Does the machine only leak on start up? or during the whole cycle? when machine not operating does it still leak?
Jun 11, 2012 | Maytag Neptune MAH6700A Front Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stackable maytag washer and dryer
Hello, on most Maytag units you can take the the front panel off by removing 2 phillips screws , 1 on each side of the front panel. With the panel off you can run the machine and see where the water is coming from. Good luck
Dec 21, 2008 | Maytag LSE7806A Top Load Stacked...
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Water leaks through bottom of Front door
The manufactures suggest putting washers on the back side of the hinge to draw the door tighter to the seal, otherwise you may have to replace the seal.
Oct 30, 2007 | Kenmore 44042 Front Load Washer
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Machine leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains). NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them). 2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety. 3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
