Question about Zebra 140Xi II Thermal Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
  • 257 Answers
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Posted on Jul 16, 2009
We must upgrade Zebra 170 XiII printer firmware. We need V18.8.0 or higher version.
The latest firmware version available for the XiII printer is V18.9.2.
Zebra P/N 49970V18.9.2M
Oct 06, 2010 | Zebra 170Xi II Thermal Printer
Tip
Used this to print from "inherited" X83 that does not show a Print option in the...
Click start.
Open control panel.
Open printers and faxes folder(in xp)
Right click on the printer icon and click properties.
Click on advanced tab and select print directly to printer option and click OK.
This will resolve most of the spooler issues.
on Jun 14, 2008 | HP Photosmart C6280 Printer
Increase Speed on Zebra 105SL
In the driver there are settings for print speed, you will aslo need to access the menu on the printer and set the speed
Apr 27, 2010 | Zebra Eltron TLP 2844 Thermal Label...
install the correct drivers from www.zebra.com
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads.html
check if printer is connect and on.
wen finish, restart the computer, he can check automaticly.
check on START-Printers and Faxs- see the printer icon - print test page
Nov 16, 2009 | Zebra Printer 140-751-00000
Hi I have a Zebra ql220 printer that prints about 4 or five blank labels in between barcodes. Is there a way to manually adjust this via the printer. I got a message on one printer about bar gap sense not...
Press and hold feed button for 2 -3 seconds and switch on printer.Printer will calibra and print test page .if problem is not solved Go to printer menu and select ribbon and media calibration.it will calibra te printer and problem will be solved
Aug 03, 2009 | Zebra Printer 140-751-00000
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Small label is being cropped at the top
Have you tried the menu settings for start top of label? If other printers work, you are talking about a configuration setting. I would get a configuration off another printer that works and look at yours real close.
May 01, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Sizing and Orientation problem on Zebra 140 Xill
As far as the size it sounds like it might not be using the right resolution these come in either 200 or 300 DPI. Make usre your DPI is set to the same as the printer. If the printer is 300 and the design shows 200 then it will print rather small on the label. Not sure about the other issue.
Mar 17, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Printer Defaults
try setting up your sizes etc on the required printer in" printers and faxes" first and then access your print system , when you then select the "print" function you will find the sizes etc that you have set up in printers and faxes are already set for you , unfortunately it will only save for a few prints and then will default ,however it defaults to the settings you have already set up in printers and faxes
Jan 27, 2008 | Zebra Printer 140-751-00000
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra 140Xi II Thermal Printer Logo
289 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
