Question about Pioneer VSX-403 Receiver
Stereo speakers stopped working
Hi there, bought new 150w speakers plugged them into stereo, worked then stopped. Speakers that came with stereo say on them 80W max. Is this the problem? have the new speakers got to much power for the stereo unit? On the stereo unit it says 130 W - not referring to anything in particular. Help would be appreciated...
  • 55 Answers
The ''watts'' are peak or rms?notice that 150 Wpeak are about 70Wrms....
Also notice if you are using ''big'' speakers you can burn your amplifier..
Posted on Nov 18, 2007
Need a new stereo to work with the old speakers
Any 5.1 surround system will work with this. It is better to be high in impedence than too low.
Feb 13, 2014 | Sony MHC-M300AV CD Shelf System
Hi r these good speakers?
Power Handling (Peak) 300W , Power Handling (Continuous) 150W , Frequency Response 25Hz-22Khz , Crossover Slope @ 4.5Khz 24Db/Octave , Efficiency (1 Watt/1 Meter) 93 Db , Impedance 4 Ohm .
what this means is that the speakers are designed for a car stereo alone, NOT stock stereo as it wont have enough power. See the one 50w x 4 ,, yeah its designed for those. All and all its not a bad deal.
Mar 31, 2011 | Planet Audio BB65PRO Car Speaker
I just bought the Ls21 external speaker system. They work but the volume is incredibly low and the sub doesn't work at all. Also it works without the plug being in. Very strange. Suggestions? Drivers? what...
OS these days are usually set up for additional hardware like speakers. But you should check the settings for the speakers from your computer first. To find out if the settings is the culprit, you can plug your speakers into another music player to test it. If the same issue arises, you may have to bring it back for exchange.
Regards
Mar 06, 2011 | Logitech Ls21 21 Stereo Speaker System 2 X...
Would this speaker work in the jamo gf-25 ?? and if not does any one know what will ?
hi,
it will not be a perfect mach. u have to purchase a speaker with long term power handling capacity of 150W and 4 ohms impedance.
ok
Jan 06, 2011 | Jamo 8.5CS Main / Stereo Speaker
Speakers have no sound coming from them.
There is not fuse for the speakers themselves. The speakers maybe blown out. I would take a speaker out and connect it to the home stereo and see if it works. I would check to see if the speakers are plugged in also.
May 01, 2010 | 2000 Volkswagen Jetta TDI
Recently bought a Lenovo Lenovo G550 laptop. Can
If I remember correctly, those speakers were supplied with some Gateway computers equipped with a digital soundcard, and the speakers take only digital input.
Take a look at the input plug and compare it to these:
If yours looks like the mono plug, your speakers will only work with the original digital card. Plug them into your new computer and you'll get nothing out of them.
Hope this helps. Thanks for using Fixya!
Mar 02, 2010 | Boston Acoustics BA735 Computer Speakers
We recently bought new speakers and the wires have
Most speakers that are not part of a proprietary system of original design will accept a spade and/or a banana plug, likewise with amplifiers and receivers.
You can also bind your strand wires or solid core wire types around the posts and tighten them down.
Feb 19, 2010 | Sony SS-X90ED Main / Stereo Speaker
Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
May 14, 2009 | 1998 Ford Explorer
Stock Speakers wont work with new stereo plzzzz HELP
U have a Factory audio auxiliary amp in the truck, the radio is just a head unit with a preamp feeding a main amp, that is behind the right rear 1/4 panel trim panel in the cargo area, if your new sound unit has preamp outputs use them, other wise u must wire around the Ford factory amplifier.
May 13, 2009 | 1991 Ford Tempo 4 Door
790 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
