Question about Roland Mc-909 Sampling Groove Box System
Memory problem my mc 307 does start, I can play and even record and save patterns. but whenever I turn off the groovebox and turn it on again, the recorded patterns are still there, but the sounds aren't! they're just set back to the standard-synth again, so I would have to set them all again everytime I restart the groovebox...
  • Tass Mann Oct 30, 2013
    @ mativatrance and other people with the same Problem I have an Roland MC-307 to with the same Problem.... ok i mean... you must @ first change the System Parameter go to Stystem at next to System (F1) than Midi (F4) and as next change the Midi RX Parameter (RX.Prog.Change & RX.Bank select & Rx.Sys-EX) to on!!!! And than, you must the Patch you have tweakt and recordet ( Tr. Rec. / Real Time ) , store into a User Storage and select this Patshes again on your Chanels you have recordet... and store the Pattern into a User memory ( I mean , it must works ;) )
  • Euge Diaz Balmaceda Jun 14, 2014
    I have the same issue. I've contacted Roland US support and the response to my question was really annoying: "We dont give support outside US" (Im from Argentina). I can understand how QA team doesnt realize about this big issue in the OS. And also, I can understand why Roland is not able to answer questions from their customers, related with issues in the Operating Systems. I've contacted in the past Korg and Novation and they kindly answered my questions... but Roland answer is "F** yourself"
Hi i just got a used MC307 and i think i have a similar problem.. when i tried to edit a sound in real time it froze, it kept playing but was locked in the same pattern over and over again.. also i seem to have a problem with one particular bass patch in the 1st preset pattern called Psyche Trance. it doesnt sound like a bass it sounds like clicking.. otherwise everything else works totally fine.. this is wierd.. its not the same as your problem but they may all be a problem connected to the memory.
Posted on Mar 23, 2010
None of my patterns save when turned off.
Likely the memory backup battery is exhausted. Replace it.
The only other options is to dump data to external recorder and reload as needed.
Jul 16, 2010 | Alesis Sr 16 Stereo Drum Machine
Rolling picture and blue screen
According to my Satellite provider tech support. More and more channels are being encoded so that recording equipment cannot capture the signals to prevent piracy. I know the premium channels use this technique now. I would call and ask tech support if there is any copy restrictions in place that would affect your VCR recording before doing any further trouble shooting on the VCR. If you can play pack a prerecorded movie fine with your VCR then it should also record fine. Also try watching the channel through the VCR tuner and I bet you will see the same pattern. The VCR can only record the signal it is given.
Hope this helps you,
Ron
Feb 24, 2010 | Samsung DVD-V5500 DVD Player/VCR
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Headphone jack output
The same problem here. I solved it like this:
You must open the device. There will be a PCB with outputs and inputs. You must must detach it by removing screws on outside and then disassemble the PCB from two plastic pins to get the PCB rotated (I used plice to detache it one by one) and the conections of jack socket visible. In my case one od the lanes to the hot pin was broken. I checked that with Ohm meter 'cause it wasn't clearly visible with an eye. So having the PCB more or less secured I started to clean the lane a little bit to have a chance to put the solder layer near the pin and breakage. Get some really precise soldering device. It's a precise job. Do not overheat the diode which the lanes goes to. After placing some of the solder I checked the new connection by placing a jack into the socket and Ohm meter once again. All was perfect and working after assembling. Piece of cake.
ZIBI
Jul 16, 2008 | Roland Mc-909 Sampling Groove Box System
MEMORY CARD PROBLEM
many games require large space of memory on your MC.. so, i suggest you get another one..
Feb 07, 2008 | Sony PlayStation 2 Slimline Console
Dc motor turning
Hi.
Better quality cassette decks use this method as it puts less strain on the motor because it dosen't have to keep starting and stopping.
John w
Dec 07, 2007 | Audio Players & Recorders
Not being able to save gow 2
One trick that I found working every time is that turn on the console, pull out memory card, insert game disk and start the game. When the game menu shows up put memory card in. From there onwards games will be loaded and saved properly without this issue hopefully
Oct 26, 2007 | Sony PlayStation 2 (PS2) Console
Loud Humming
It's possible a fan or a hard drive is going bad. When the bearings in those devices start to go out they a start making noises like that.
Jul 18, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Playback
Hi Vitt, There are two ways to switch off the AudioDream, the power switch or holding the Menu button for 5-6 seconds. When the power switch is used changes in the settings are not saved to memory. After changing settings always power down the AudioDream by pressing the Menu button. This will save the changes you made. Have a good one! El Duderino
Nov 17, 2006 | Packard Bell AudioDream MP3 Player
Roland Mc-909 Sampling Groove Box System Logo
400 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
