Question about Dell Inspiron 1525 Notebook
Broken hinge The plastic on the hinge on the left hand side of my screen has cracked/broken how would i fix this?
  • 400 Answers
Depending on the damage you can try to super glue it back.
Apart from that you will have to take it to a laptop repair shop and see what they say.
Posted on Jul 16, 2009
  • Fabio Sep 04, 2009
    Any luck?
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Macbook pro hinge crack
If the laptop still works you were lucky. The screen will die eventually when you open the lid too far again.
Take it to Apple and get it fixed.
Mar 28, 2014 | Apple MacBook Pro Notebook
How do you fix a dm4 Hinge that is broke where it connects to the screen
You can buy hinges on ebay at:
http://www.ebay.com
Just type your computer make and model in the search followed by lcd hinges.
If the hinges are broken where the lcd screen connects to the base of the laptop then you will have to remove the screws from the bottom of the laptop and remove the strip that is at the top of the keyboard to get to them.
If the hinges on the side of the lcd frame is broken then you will have to remove the plastic strip that is around the lcd screen. Remove the plastic or rubber bumpers on the plastic strip then you will see screws to remove to remove the plastic strip. Then you will see hinges and screws on the side of the lcd screen that you can remove. Once you have them removed you can lean the lcd lid forward so that it drops in your hand. Don't let it drop on the keyboard, just into your hand and not too far because there is a cable on the back of the lcd that you don't want to damage. The cable can be taken loose from from the lcd at the back near the top if you like. Sometimes there might be a piece of tape securing it. If the lcd screen does not come out then there are screws on the 4 corners that is securing it and the hinges.
May 13, 2012 | Computers & Internet
Paper gets jammed everytime it copies, it would not go through. There's no paper stuck either. Canon MF6530
I am assuming its jamming in the ADF when you are attempting to make a copy, if so open the top lid of the scanner and check both hinges and make sure they are not broken or cracked. The slightest crack in a hinge will offset the paper path and cause jams. If the hinges look good check for a clear plastic mylar strip under the lid, it will be on the left side. If that plastic strip is missing that will also cause jams.
Apr 11, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
NINTENDO DS BROKEN "PLASTIC RING HINGE"
nono no dont my ds had the same problem it will work as long your extemely careful but if you drop and a hinge missing the top screen will break and it is unfixable i have tried
Mar 24, 2009 | Nintendo DS Lite Console
HP C500 Presario Hinge
no ....before you lay your hand call hp and tell them my left hinge is broken and if there is a recall on your notebook it will be fixed free by hp
Feb 15, 2009 | HP Compaq Presario C500t Notebook
Screen is blank unless a flashlight is shown on the screen. Prior to this happening laptop was dropped and the left hinge broke off. Could something else have broken off?
sounds like the backlight system of your screen is broken. You may have to take it to a laptop repair shop, preferably an authorized service center to have it fixed
May 02, 2008 | Computers & Internet
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Dell Inspiron 1525 Notebook Logo
477 people viewed this question
Alun Cox
