Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
TV IS DEAD. NO POWER AT ALL. HAD A SERVICE TECH LOOK AT IT. HE SAID THE PCB HAD TO BE REPLACED. IS THIS A COMMON PROBLEM? IF SO , WHY?
  • 304 Answers
If the set is totaly dead then the first place to start is with the SMPS (Switched Mode Power Supply). However sometimes other parts will cause the Power Supply to short out as well. If and when the Power Supply is replaced and the set comes back to life and operated with a Menu then you are probably ok. Note: On your set when replacing the SMPS the tech Must adjust the SMPS voltages to the Panel Voltages. There is a sticker on the Panel that list the voltages the tech must adjust on the SMPS.
Posted on Jul 17, 2009
MFC-9840cdw with "print unable 36. Sometimes I can reboot and get it to print a few pages, but then the error comes back. I've cleaned and checked for ink, paper,etc. everywhere, but can't resolve th
Ok, here is what I found with a bit of internet research. Print Unable 36 error stems from an issue with the High Voltage Power Supply Printed Circuit Board (HVPS PCB).
Possible issues are:
1. The tech accidently didn't properly seat the connectors when re-hooking up the cables if indeed he or she removed any in dealing with your Error Code 32. "Check the two harness connections between the transfer HVPS PCB and Registration Relay PCB, and the two ones between the Registration Relay PCB and Engine PCB. Then reconnect them." If you try this yourself, make sure the machine is unplugged and cycle the power switch to discharge any power supply capacitors. You don't want to mess around with the high voltage. Best is to take the unit back into the tech for him or her to check it out.
2. The HVPS PCB has gone bad. If the machine is still under warranty (check for your receipt), don't go any further and just call Brother customer service at 1-877-436-2665. According another user, the part was shipped overnight and a tech came out the afternoon after he called and installed the part within 2 hours.
3. The Engine PCB failure. Replace the Engine PCB assembly. See warranty service recommendation above.
Start with #1 and if that doesn't resolve the issue, move to the next steps. If under warranty, have Brother do the service. If out of warranty, you'll have to examine the costs vs. buying a new machine.
We just bought another Brother printer (an MFC-9460CDN on closeout sale via Best Buy (~$329.99 and free shipping to the house)). Love Brother machines and service. Very robust in general and fairly easy to repair. I just replaced an MFC-8840DN that is more than 10 years old, and still working, though getting worn out.
Hope this helps.
Feb 16, 2015 | Brother MFC-9840CDW Laser Printer
Samsung HLP5685 W
yeppers..the ballast has taken early retirement...can you unplug the ballast output, and see if it's running into a short condition?
Mar 09, 2008 | Samsung HLP5085W 50" Rear Projection...
Tv wont tyurn on and the DISC light is flashing 3 times
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem, and do take care in handling the television because it contain high voltage.
Thanks
May 14, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My Directv H21-200 will not power on. Even after leaving it unplugged for a while. I need to know if there is a fix or if it's fried.
Take the unit aparts,the power fuse at near the a/c power supply cord.Check for the power fuse.If the power fuse it is dead,replaced it,u have a 70%-80% the unit will work again.If the unit power fuse it is good.Than the unit it is fried,it could be anythings are dead on the unit PCB board,now u must have great electronic skills and troubleshooting skills to find out where it is and replaced it electronic parts on the unit PCB board.Require alot of skills at this points.Not worth the effort.It time to buy a new one.
Apr 26, 2011 | Directv H21 DTV Receiver
No power. Will not turn on. Since Canadian Tire would not take it back, I decided to open the back and take a look myself. I am a electronics tech. Haven't worked on TV's much. It seems the power...
So u a Tech.Very common on this LCD or Plasma tv sets are dead leakage capacitors.Check all those capacitors,these capacitors alway bulges up on it top or puff up on it top.Replaced all these defective gas leakage capacitors,that bulges up on it top or puff up on it top.Ur tv will power up and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 26, 2010 | Proscan 32LA25Q 32 in. LCD TV
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
I have an emerson tv and it will not power on at all. The little light wont even come on.
Solution 1 was just step 1. If the outlet gets power and the fuse or circuit breaker is ok, then U have a bad tv. That seems to be the most common problems with lcd's when they go bad. They either give the blinking light and not coming on, or they go completely dead. Most common causes are a bad power supply or a bad board/PCB/Circuit board.
Apr 20, 2009 | Emerson EWL3706 37 in. LCD Television
Samsung HCM653W 65 in. Television
Dear,
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb,sub.samsung part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per"Partsstore.com. I have no idea where you can find the power supply board. If you find it,please let me know.
Thanks.
DollarTech
Jun 18, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
542 people viewed this question
Jerry Greenberg
Jerry Greenberg
