Radio Communications Logo
e
earl wockasen Posted on Mar 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set band - Galaxy Radios DX-2517 CB Radio
Mike Charette
Level 3:
Genius:
  • Galaxy Radios Master 1,847 Answers
  • Posted on Mar 22, 2016
Mike Charette
Level 3:
Genius:
Answers
1847
Questions
Helped
490526
Points
2212
Turn the band selection knob to channel " D " thats the CB channel.
How do i set the time on my band
  1. Access the Settings Menu: Depending on your band, press the dedicated settings button, swipe left or right on the touch screen, or use the corresponding app on your smartphone to access the settings menu.
  2. Find the Time Settings: Look for an option related to time settings, which may be labeled as "Time," "Clock," or "Settings."
  3. Set the Time Format: Choose the desired time format, such as 12-hour or 24-hour format.
  4. Set the Hour: Use the navigation buttons or touch screen to adjust the hour. Some bands may allow you to tap on the hour to cycle through the available options.
  5. Set the Minutes: Similarly, use the navigation buttons or touch screen to adjust the minutes.
  6. Set the Seconds (optional): If your band allows, you can also set the seconds by following similar steps as above.
  7. Save or Confirm: Once you have set the desired time, save or confirm the changes by pressing a dedicated button, tapping on a checkmark or confirmation icon, or following the on-screen instructions.
  8. Sync with Smartphone (if applicable): If your band syncs with a smartphone app, make sure the time on your smartphone is accurate, and sync the band with the app to ensure the time is updated.
D Link Not Working
Check the router internal setting under the WIRELESS SETTINGS section. The 2.4 and 5 GHz bands are separately enabled. It's possible the the 2.4GHz band may be disabled. Also check under ADVANCED WIRELESS SETTINGS to ensure that the TRANSMIT POWER level is set correctly. If that is not the problem, check to see if you have recently located any electronic wireless device near the router that can interfere with the band. Many cordless phones use that band and can interfere with transmission and reception. Finally, if nothing else works, I would record all router settings and attempt a router reset to see if that solves the issue. Otherwise, it would seem to be a failure of the router.
How can i unlock my moto q9h to use any sim from a network
Set band GSM 900 - 10*0*3
Set band DCS 1800 - 10*0*4
Set band PCS 1900 - 10*0*5
Set dual band GSM 900/1800 - 10*0*6
1helpful
I need to know what each knob and switch on front of radio should be set at. i know about the squelch setting and mic gain (at least i think I do) but not sure about all the other settings for your...
To use this radio on the CB band, you set the 10 Khz switch to OFF, and then turn the band switch to A/E.
Here is a Frequency Chart.
When the 10 Khz switch is on OFF, the band switch is E,F,G,H. When the 10 Khz switch is in the ON position, then the band switch is A,B,C,D.
So when you are on band E, which is when the 10 Khz is OFF, and the band switch is in the first position, it is on the E band.
I would get your self a Frequency counter. It makes using a radio like that much easier.
Hope this helps!
3helpful
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Dual band setup/wep
you have dual band router.
It must be working on the 5 GHZ and 2.4 GHZ .
if you access the router set up interface , you will find the wireless settings of the router.
For 5 GHZ , you can set up different SSID than the SSID of 2.4 GHZ.
Make sure that both the wireless network names will be different.
You use the same security settings for both the bands.
For this you will need to access the router set up interface.
Click Here for more info
Different ink settings banding
Try doing a printer head alignment, sounds like the printer heads are overlapping causing the banding.
Screen colors also never match perfectly to the print either, whist your monitor can produce millions of colors, the printer can only do some many.
BC72XLT
You can't add to the preprogrammed search functions, but you can program frequencies from these bands into any locations you wish within the 100 programmable channels, where it will jump bands while scanning.
15helpful
Clarion drb4475 set the clock
Found this elsewhere on this site:
To set the clock, press and hold BAND and DISP to display the clock. Press and hold BAND and DISP until the display flashes. SEARCH left to adjust the hours; right to adjust the minutes. Press BAND to set.
5helpful
3answers
Setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
