Question about Sanyo Televison & Video
I have a sanyo pdp42wvi how can i conect a free veiw box to watch tv on ot... what leads or parts do i need,and were would i get them
  • 6 more comments
  • marklawman Jul 16, 2009
    this is not a tv its a monitor 42 inch ,,so i can not use a scart lead
    ive been told that there is a converter box or lead vga that i can buy that will allow me to watch my freeveiw box
    i got a lead but it still comes up blank.. when i try a difrent lead s video i get a black and white picture
  • marklawman Jul 17, 2009
    im still not sure what leads im looking for thoe,, this is were i need the help as i got a set of leads but that was a waste of money,,
    i have scart on freeveiw and rgb on monitor,, but tryed a lead to both but still no good
    what is an rca card
  • marklawman Jul 18, 2009
    its vga to scart,, but i tryed a lead and it did not work,,
    its vga to scart... but ive tryed a lead and it did not work
    Brigadier General:
  • 7,191 Answers
Hi Mark,
Based on your description of the problem, you'll have to buy an external TV Tuner box for connecting FreeView box to your monitor. Connect the FreeView box to the monitor through the External TV tuner box in the following order:
Connect the RF OUT from the Free View box to RF IN on the external TV Tuner box. Then connect the VGA OUT of the external TV Tuner box to the VGA IN of the monitor.
You can purchase the External TV Tuner box at a Computer Hardware shop.
Also, please provide us with the model number of the Free View box so that we can guide you accordingly.
Hope this solves your problem. Thanks.
Posted on Jul 18, 2009
  • AliTech110
    AliTech110 Jul 18, 2009
    Hi Mark,
    You can also buy the SCART to RGB converters / adaptors to connect FreeView to your monitor like these shown in the attached pictures.
    This will be the easiest and cheapest option to connect your monitor and free view box.
    Thanks.
    President:
  • 2,777 Answers
Hello there, I'm pretty sure you can find what you are looking for at:
http://www.beststuff.co.uk/specialist_rgb_leads.htm
Hope this helps!
Thanks
Tim
Posted on Jul 16, 2009
  • 1 more comment
  • Tim Grayson
    Tim Grayson Jul 17, 2009
    Well you will want either the RGB Scart to 15 Pin HD VGA if your
    monitor has a 15 pin INPUT plug on the back of it (you may have to
    remove your current monitor cable). Do you have any idea what kind of input its going in to?
  • Tim Grayson
    remove your current monitor cable. Do you know what kind of input you are using? Let me know.
  • Tim Grayson
    Sorry about the double comment, it told me the first one didnt go through, but apparently it did.
  • 2,359 Answers
Your 42" Sanyo pdp42wvi should has multiple RCA jack inputs for device like DVD,VCR or external tuner.
You will need
1X digital TV tuner box
1X triple ends RCA card
1X good TV coaxial antenna to pull in all the channels
Find an un-used RCA connector set (Example: VIDEO-2)
Connect the other end to digital tuner buy and follow the box tuning instruction.
You will get a lot of channels if you have a GOOD antenna.
Good luck
Posted on Jul 17, 2009
  • Vincent_G
    Vincent_G Jul 17, 2009
    It's RCA cord.
    Check the front and side for
    set of 3 RCA female jacks
    or
    set of 5 RCA female jacks
  • Vincent_G
    Vincent_G Jul 18, 2009
    Here's the pin out of SCART and 15 pins S-VGA connector.
    http://en.wikipedia.org/wiki/SCART
    http://en.wikipedia.org/wiki/VGA_connect...
    It's late. I will follow up on this in the morning.
  • 336 Answers
Hi there, If you freeview tv output is composite type (3wires, red white yellow) you need a composite to RGB adapter sinch your monitor input is RGB. If you freeview have scart, you can get a scart to RGB adapter. Just type what you want in google. there are plenty of suppliers for those converter. Take note: audio line is separate. You can directly plug the composite audio out of you freeview tv to your monitor audi in.
I hope this helps.
cheers!
  • jessy Jul 17, 2009
    To help you more, I need to get additional info from you.
    1. What freeview tv box are you using. Does it have SCART, component, composite or svideo out?
    2. Can you please comfirm the video in connector of your monitor, does it have rdc 15pin pc in,
    svideo, etc.. You have mentioned you have connected using svideo and you've got black and
    white, can you please clarify how did you connect that?
    Finally, I think what you need is the one like in below link
    http://www.lektropacks.com/view_product_...
    You need some coonectors to use it depending on the slots available from your freeview tv.
    kind regards.
  • jessy Jul 18, 2009
    RCA card usually used in PC to have connections for compotite or RGB format. I think this would not be a solution to you problem.
    Is your RGB monitor, a 3 wire cable or 15pin PC in?
    if 15pin PC in, you will be needing this to watch from you freeview TV
    or
    http://www.maplin.co.uk/Module.aspx?Modu...
    You can search to google with cheaper similar products.
    Kind regards.
  • 3,741 Answers
You will have to get the tv tuner card.to watch the tv.the monitor wire goes to the tuner card and tuner has the card to be connected to the tv.in this way you can watch the tv.
you can get the parts at
www.radioshack.com or at
www.bestbuy.com
check out both for best deal.its called tv tuner card.give them your monitor model and brand name if required.other wise its ok.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
  • charlymonty Jul 18, 2009
    get your tv model number and the cables which you got at present .at a nearest tv/moniter store.as they will check out the wires which you got and provide you the exact type of wire model and number which you should actually buy.so it will not make any confusion.about which card or cables/wires are to be ordered/bought.
    thanks.
  • 3,037 Answers
Plug your new Freeview set-top box to your existing TV aerial antenna. Connect another lead to your TV set's SCART socket, and you should be ready to go with this tv. A SCART connector is something you'll find on more modern TV, video, DVD and games units - They have 21 pins, and carry audio, video, switching commands and an earth. You can get these cables at a Radio Shack or any electronic or tv store.
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 16, 2009
    I'm sorry but the number you gave me is a screen model number not a tv model number which is why I assumed it would have a scart connector on it. If you can get me a tv model number that I can look up what you need, otherwise an electronics store can get you the box to convert from SCART to whichever connection you have available
We want to connect our Sanyo VHR-795E to a recently purchased LG freeview TV to record programs. Our best efforts so far have resulted in recorded picture but no sound in playback mode. We have tried...
Some TV's have different settings for outputs at scart sockets. Read the manual on the TV to see if it mentions what the scart(s) sockets output.
However I think you might find it better to connect your VCR to a seperate Freeview box, that way you can watch a different channel to the one you are recording. Box's are cheap at the moment you can get one for around £10 on E-Buyer.Com.
Aug 23, 2011 | Sanyo Televison & Video
We have a Sanyo CE32DFN2-B digital television. Our region has completed the digital switchover today and now we cannot tune the TV into any channels at all. Is this because our TV is too old to cope with...
Ur tv have a big back like hunt back creature?Yes?This tv it is not a Digital tv.It is an old CRT tv-tube analogue design tv.This tv still will work and have a broadcasting incomming signal if it is hook up to a pay services tv like Satalites tv like Direct Tv,Dish Network tv,Timewarner or Cox Cables services and ATT U verise or Verizon Fio digital hook up.If u wanted to watch a switch over FREE OVER THE AIR DIGITAL incomming broadcasting signal for this tv it will not work alone,the tv must have be to hook up to a BOX that call a DIGITAL CONVERTER BOX than this tv will work for a FREE OVER THE AIR DIGITAL broadcasting tv channels stantions.This DIGITAL CONVERTER BOX are no longer on sale on regular Stores.Tries websites like Amazon.com,Ebay.com will able to buy these BOXES so call DIGITAL CONVERTER BOX.
Aug 17, 2011 | Sanyo Televison & Video
How do I retune my Thomson Digital TV 24WK25UG after digital switchover in Granada area
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
Dec 04, 2009 | Thomson 24WK25U 24" TV
Picture goes black
are you using the built in tuner or a set-top-box? Or watching DVDs when this happens? Are they connected through SCART?
First check the cables which lead the signal -antenna/satellite/cable if they are not broken or with damaged connectors.
Scart cables sometimes tend to have too heavy and stiff leads for the weak SCART plugs. This is NOT an issue with HDMi sVHS or any other.
If it's none of these the problem is probably a power lead of the screen and if you don't feel like opening the back of the box, it would be just fine to take it over to a repair shop or to the centre where you bought it if you still have a warranty.
if not find a Sanyo service near your location(refer to http://sanyo.com/ ) or take it to any home electronics repair shop.
rate pls
Apr 16, 2009 | Sanyo DP42746 42 in. Plasma Television
Your HDTV does not support HDCP
This is normal in HD 4250.Problem is ( box software).You need to disconnect HDMI cable from the box,or leave TV "ON" during recording.
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
How do I play my Sanyo VPC-CG6GX recording on a TV & make copies
I was just looking in the Sanyo CG6 Users Manual for you about how to watch your videos on your TV.
I noticed on page 136 there is a TV Systems Setting, to choose between NTSC (american TV) and PAL (Asian or European TV). Perhaps it is set to PAL while you are in North America, or vice versa?
Otherwise, you seem to be on the right track; when the miniplug is in the camera and the yellow, white & red leads go to the TV, the camera should by using your tv instead of its little screen.
Jan 09, 2009 | Sanyo VPC-CG6 Digital Camera
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Conecting plasma to receiver using hdmi lead
if you receiver has a Aux function an is still unused try to hook your playstation audio rca up to it directly it will work either way, Hope thats what you mean, An Hope it works
Oct 23, 2008 | Yamaha RX-V863 Receiver
Philips Convergence for 55PP8620/79
Yes the box marked sanyo is the focus and screen control box. All stk Convergence ICs for rear projection TVs are made by Sanyo, which was the origional producer of the STK series Convergence IC. You need the convergence repair kit for the DPTV series rear projection which consist of two STK392-120 ICs and 11 6.8 ohm 1watt metal film resistors. You can get the repair kit for your model at the following link , they do ship to Austrailia however they do have an international shipping charge which must be purchased for orders outside the north American continent,. They also probide free installations instructions with pictures and free tech support. Heres the link.
http://servicemanuals.vstore.ca/
Sep 15, 2008 | Televison & Video
Televison & Video Logo
134 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
