Question about Jandy LAARS LX250 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX
Jandy LX250 LT Pool Heater High Limit Switch
The High Limit switch LED is lit and the heater will not fire up at all. Any help to resolve the problem would be great. It is a natural gas low NOX unit.
Thanks
  • 128 Answers
Jump the High limit switch. If it fires the switch is bad
Posted on Aug 23, 2009
  • Scott Corey-reid Feb 13, 2014
    problem is rarely due to a faulty safety switch. the high limit will open due to an over temp situation. So most likely something cases it to open. Simply saying "replace the switch" is a half assed attempt from so called techs
Jandy Lite 2 Pool Heater won't stay lit
This could be a number of things, high limit switch, temp sensor or clogged burners. If the heater does not get much use cob webs could be the culprit. To test the high limit switches you can disconnect them temporarily and use a jumper wire , if it fires and stays lit then you have found your problem. Just disconnect the 2 wires , and use a separate wire to connect the two together bypassing the switch. This is a safety feature and should only be jumped as a diagnostic tool and not left to operate this way.
Dec 06, 2013 | Jandy Pool & Spa
Tip
Laars LX250 Manual Download
Laars LX250 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX250 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX250 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars Lt 250,000 Btu Heater
Jandy LX250 natural gas pool heater will not start heating. Turns on but no heat. Low Pressure Flow
if filters are clean check pressure switch see if 24 volts ac on both sides if not check copper line for clog if ok bad pressure switch you can jump just to check
Mar 27, 2012 | Jandy LAARS LX250 - PROPANE, DIGITAL...
How much time would a technician need to replace a high limit switch on a Jandy Pool Heater?
Thank you for posting your question here on Fixya.com.
It should only take a few minutes to actually replace the part; quite a bit longer to diagnose the problem depending on the way the switch failed and overall condition of the heater. It would not be unreasonable to get a bill for an hour to troubleshoot and repair a heater with a defective high limit switch.
John
Sep 21, 2010 | Jandy Laars Lt 250,000 Btu Heater
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
High Limit Swtiich message
The high limit switch is one part of a safety loop circuit that must work before a heater can fire. It's purpose is to ensure tha tthe heater will shut off in the event of a thermostat failure or if the internal core gets too hot due to a lack of water flow. If the switch is failing, it needs replaced. There are 2 so you can replace both or make an attempt to determine which one is bad. It is best to replace the pair.
Nov 18, 2008 | Jandy Laars Lt 250,000 Btu Heater
Jandy LAARS LX250 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX Logo
1,120 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
