Question about NEC MultiSync FE700 17" CRT Monitor
How do you put a monitor into power save?
NEC MultiSync FE700 17" CRT Monitor - never sleeps to save power or monitor from burning out.
  • minespress May 11, 2010
    Does it not even go to sleep when your computer is shut down? I don't mean that the computer is asleep, but completely powered off.
    And does the monitor go to sleep if you disconnect it from the computer?
  • 400 Answers
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Posted on Jul 16, 2009
How do you get it out of the power save mode...?
The monitor usually goes to the power save mode if there is no Video signal input. Check your VGA/HDMI cable(the cable which is connecting the monitor and the system) try bloing air through the connectors and reconnect the cable properly. Hopefully this will resolve the issue.
Sep 19, 2013 | NEC MultiSync FE770 (White) 17" CRT...
The screen is majorly out of focus how do I fix and or where do I send it to be fixed?
This is an older monitor that night be getting screen burn. You can get a new one for sale used or a new one pretty darn cheap.
Oct 09, 2009 | NEC MultiSync FP1370 (White) 22" CRT...
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
My monitors light is blinking all the time n no pic Nec Multisync FP1355
there is a setting you can access from the monitor menu button. make sure that the monitor is set for the cable you have running to it.
If you are using DVI use the digital setting.
Anything else, use the analogue.
Jun 28, 2009 | NEC MultiSync FP1355 (White) 22 in.CRT...
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
Monitor will not get out of sleep mode
Press F2 or Delete key or the key specified to get into BIOS. Go to power management and select S1 & S3 for Power management. Save > Restart. This should solve the problem
Jan 05, 2009 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
NEC P1250+ hisses and scrren blips intermittently
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Sep 19, 2007 | NEC MultiSync P1250 Plus (White) 21" CRT...
NEC MultiSync FE700 17" CRT Monitor Logo
119 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
