Question about Canon Pixma iP2600 Photo InkJet Printer
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
  • Tim Yates May 11, 2010
    Make sure the paper is in the right posistion otherwise it will jam even though it looks good to us. Also, pull out paper, throw away used paper or paper that has jammed, completely inspect printer top to bottom, inspect roller tabs, also make sure firmware and drivers are up to date
    pull every thing apart, check the sensors, roller tabs ink everything, put it back together
    Scholar:
  • 71 Answers
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jul 16, 2009
Paper will not feed
Check inside the machine at both ends of the cartridge carriage path i.e. far left and far right. Check for scrunched up paper and note, if it is there, it will likely be black with ink. If found please remove. Next take the back off the machine (there is usually a removable plate there to get to paper jams) and remove anything you find there. Also look right through towards the front and see if the little drop down paper feed sensor arms are all visible and swing freely. If not, fix them as you can. Once you have done these things, put everything back together and leave the printer powered off for 30sec. Power it up and see what happens. If you are still no go, either take it to a service tech or check to see if your insurance covers printers being beaten to death with a 4 pound hammer.
May 14, 2015 | HP Office Equipment & Supplies
Hello Cindy Wells, I saw you on Fixya.com and I am having a bit of a problem with my Canon PIXMA MP490. Basically every time I try to print something the printer will start working (i can hear it...
hi there,
it may be that a paper sensor is picking up a small piece of paper in the printer. Has any paper ever torn in the printer? if so there may be some left behind. Carefully inspect the printer to see if there is any small pieces of paper in the printer. You could also try unplugging all cables and taking the outer cover off to inspect closer.
Re the ink cartridges, inkjet printers are notorious for ink drying out in the cartridges and the nozzles blocking with old ink, if the printer is not used at least once a week. It happened to me, i had to get a new printer.
Hope this helps
Tom
Jul 22, 2011 | Office Equipment & Supplies
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
Error code e 2
It means no paper...
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 25, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
Printer will not work. Error E3
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error - USB
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP2600 Photo InkJet Printer Logo
430 people viewed this question
old marine
old marine
