Dyson front loading washing machine nearly always shows the error message 'Overload Reduced Performance'. It does not matter how much or how little is put into the drum, it will nearly always show the same code. It seems to run through the program (any program) OK then shows the error when it stops. Any ideas?
how do i reset the machine to remove fault code. the fault is fixed but fault code is still showing....
(More)
how do i reset the machine to remove fault code. the fault is fixed but fault code is still showing. is there certain buttons i can press to clear it?
Dyson Washing machine has no power and i would like to know how to get the clothes out. have drained...
(More)
Dyson Washing machine has no power and i would like to know how to get the clothes out. have drained water and checked fuse etc but doors will not open
outer door will not lock m/c keeps tellin me close outer door and press start have tried taking...
(More)
outer door will not lock m/c keeps tellin me close outer door and press start have tried taking locator out of outer door and placing it in on its own still no good
My machine keeps stopping through the cycle, unable to read error message as the display is only...
(More)
My machine keeps stopping through the cycle, unable to read error message as the display is only partly readable, when the start button is pressed it will go through the cycle to the end, but the clothes are soaking wet & full of suds, any one havig similar problem?
