Question about Canon PowerShot A75 Digital Camera
Out of focus with blured streaky monotone display.
Suspect that the camera has been dropped, there is a chip on the bottom of the inner lens metal casing (engraved), it sometimes comes into focus and after some time the color returns slowly, the pics have strait evenly spaced horizontal lines.
  • rastatab Nov 18, 2007
    oops forgot to read the other posts, sounds like the ccd sensor is the problem.
  • rastatab Jan 21, 2008
    Took the camera to a camera shop that a friend of mine works at and it was confirmed that it was the ccd, the company also does the warranty repairs for Cannon and the probability of getting it repaired, because it was damaged (even slightly), under warranty was about 1% and they wanted $20 shipping costs up front. Am going to pull it apart just to see how hard it really is.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 19, 2007
Amazing. I was about to buy a new camera, but I just called Canon and they said they would fix it free. Thanks t00nz!
- Mike
Posted on Jan 29, 2008
Dis you check the front lens? is it still clean and shiny?
Only clean a lens with a lens pen or tools special made for lenses. Normal cloth, and paper for sure can scratch the lens. The coating on a camera lens is very delicate and needed for the quality of every shot.
Feb 12, 2014 | Toshiba PDR-M25 Digital Camera
Auto-focus does not work
lower focus mirror post needs to be fixed
Mar 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Fuji finepix f50 camera was dropped with lense out, and now wont return. it also says focus error on screen. I have the same problem and Fuji want £88.00 to repair it - you can buy a new camera for...
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
Feb 13, 2009 | Fuji Finepix F50FD Digital Camera
The shutter inside fell out.
You must be referring to the mirror. In the second part, you must be referring to the focusing screen. If you have not dropped it, there is no likelihood of this getting damaged. You could probably be looking at the split image screen. There is no quick solution for the problem. Please take the camera to the nearest service center.
Jan 29, 2009 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Actions shots are blured
The various solutions include:
try to set focus range (settings), to infinity or to an approximate distance to the object you need to take a photo of as sometimes the automatic setting does not always do a godd job at focusing , or look at the lens when it is on if its got grease use a wet camera lens cleaning kit (someone touched the glass of the lens ) a s grease makesa it hard for the camera to focus , hence blurrig or go into your options and lower the iso mode or take it off night node if any as the iso mode leads to high exposure time which means any light that changes would record as a smear hence blurring or use flash.
Nov 14, 2008 | Cameras
Nikon 18-55mm lens is stuck , even when not on camera how can i fix it
By "stuck", I'm guessing you mean the focus. Flip the switch on the lens from 'A' to 'M' if it is.
If the lens won't zoom, hand it over to your local camera lab for repair.
Jul 27, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Cam blured
look and see if there is a way to adjust the focus on the camera. On some logitech cameras that center lens piece can rotate, allowing you to change the focus.
Jan 22, 2008 | Microsoft LifeCam VX-1000 Webcam
I tried following methods and it solved my problem.
Turn OFF the camera, and pat the camera case (those metal parts) with your fingers with a bit of strength on each and every direction for several times while pointing your lens to different directions as well. Turn on again and it might work, if not, use some more strength (if you really can't use it now things could hardly be worse anyway...but avoid the LCD and those buttons). It looked that such problem was caused by some stuck focusing mechanism, at least in my case, and a bit of shock "resets" those lens to the original position, and we are happy.
Jan 04, 2008 | Konica Minolta DiMAGE F100 Digital Camera
Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Jun 13, 2007 | Nikon COOLPIX L3 Digital Camera
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
Canon PowerShot A75 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
