Question about Acer Aspire 5004WLMi Notebook
Laptop turn off when I am using it. - Acer Aspire 5004WLMi Notebook
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is the laptop running very hot? Does it boot up again after it cools down?
    Scholar:
  • 95 Answers
Hello
you can follow these steps to figure out the problem..
  • check the battery...you can do this by checking it with another battery. Or you can go to the screen saver option and select power button, there you will find power meter. Check at what rate the battery is discharging..but you can do this only if the system is turning ON now.
  • If the battery is OK try system restore.
  • if system restore is not happening check the RAM.
follow this steps and tell me the results...
Thank you
Posted on Aug 18, 2009
Forgot bios password laptop
Turn laptop off, unplug power and battery, use a screw driver to get back plate off. Then unplug the CMOS battery. Put battery back in, turn laptop on. Turn laptop off. Plug cmos battery back in. Put battery back in and when you turn laptop back on again password should have reset :)
Sep 05, 2013 | Alienware PC Systems Computers & Internet
My Toshiba Satellite M65-S809 Laptop will not turn on! However it turns on randomly sometimes when i toy around with it, but that happens rarely. I tried removing battery, and cable to take out the static,...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 18, 2011 | Toshiba Satellite M65-S809 Notebook
My labtop wont turn on
Aug 18, 2011 | Computers & Internet
My compaq presario m2000 laptop turns off automatically. When I turn it on again it turns off after about 10 minutes.can you please help me solving the problem?
Welcome to FixYa!
Jul 12, 2011 | Compaq Presario M2000 Notebook
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
I have one problem in my laptop toshiba C640. i use win xp as my OS. my laptop if i has shutdown this laptop, during 5 or 10 minutes my laptop is turn off. suddenly after 5 or 10 minutes my laptop is turn...
Okay, when you turn the laptop on keep tapping F8, and then goto the option Safe mode. login there and wait to see if this happens there as well. If no, then its a software problem and you can revert to me and I will tell you more about it. If yes then turn your laptop upside down and take a vacuum cleaner and clean the bottom of the laptop.
If you are using the laptop on a bed or sofa, then use it on a table or get a stand for it, so that there is some ventilation space for the processor fan to take out the heat.
If this does not help, then revert.
Thanks. If this was helpful, then kindly rate me.
Nov 07, 2010 | Computers & Internet
When I turn my laptop on, a message says:"Turn off computer, check fan".
Best solution I would recommend would be to take a can of air to it. Give your laptop a good once or twice over.
Cleans it good :)
Aug 22, 2010 | Gateway (8007054) Laptop Heatsink
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
Turn off automatically
its in the "performance information and tools" file in the control panel. when i click "rate this computer" link, my laptop will turn off automatically. after that, when i turn it on again, it seem like my laptop becoming unstable. it will turn off anytime it want.
Oct 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
I have a Acer aspire 6920G laptop. Now i want to turn on the side blue lights during battery mode. Because when i use the laptop in battery mode this turned off.. Any body has any idea??
at battery mode....you cannot turn on the blue lights because the battery is low at that time....due to that it will not turn on the blue at that time....if you want to turn on blue lights during battery mode when you use your laptop in battery mode then the only way is to charge your laptop when your laptop is in battery mode.....there is no other way
Sep 18, 2008 | Acer Computers & Internet
Acer Aspire 5004WLMi Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
