Question about LG WM-2277HW Front Load Washer
Wm0532hw error code LE comes up but only when loaded with clothes...when it is empty it runs fine through out the cycle.
  • 6,784 Answers
HI. this is a major warning that is signaling an issue with the drive motor. it may be burning out or, the hall sensor could be faulty as well. check the following to address this issue further.
POSSIBLE CUASES
  • The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
  • The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
  • The hall sensor is out of order/defective.
Posted on Jul 16, 2009
  • Michael Masters
    Michael Masters Jul 17, 2009
    To Clarify, Have the motor and motor wiring harness inspected for loose connections. it is possible that the harness is the issue but, it is highly unlikely. I would , also, have the Hall sensor inspected as well for faults.
    The most common issue will be a failing drive motor(weak motor).
LE error on LG 2277HW
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
My clothes were in the washer and when I went down to check there was an error code. LE The clothes were still wet, and appeared to not have gone through the rinse cycle.
The LE is caused by over sudsing OR clothing trapped between the tubs. The LE: hall sensor shorted/destroyed from sudslock or clothes between tub. Correct the issue and party on.
LG errors:
UE: Imbalance: Load too, small too large
PF: power failure momentary interuption of shocktricity
LG service manuals and repair notes.
Apr 17, 2011 | LG WM2487H Front Load Washer
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Replaced sensor on motor and ran find empty put cloths in washer runs for a bit then le code comes up help
LE means a locked motor error. sounds like you already replaced the hall sensor so the next thing to look at is the Stator Assembly it may have an open circuit.
Nov 07, 2009 | LG WM-2277HW Front Load Washer
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
729 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
