Question about Marvel (6SBARBSG) Wine Cooler
Noisey, loud shrill
Marvel 6SBARE61 undercounter beverage/wine cooler w/glass door, installer 5days ago.
(1) Noisey, loud shrill, like a continues bird chripping or high pitch electrial sound.Very annoying.
(2) The temperature set point is 40 degrees, drops to 39, the warms up to 45 then runs every 20 minutes. Then cools down to 40.
(3) One shelf comes off track in the back. please so advice.
(4) This unit puts out a LOT of heat, there are no obstrucions to the front.
repairmen said that the digital temperature readings are not accurate and should be expected. And that older units with a dial numbers system was better for the lay person/consumer.
Am I expecting to much from this unit?
    Novelist:
  • 101 Answers
If you just got the unit you should contact your dealer for warranty service. The only noise you should hear is a slight hum of the compressor and the soft blowing noise of the condenser fan. It sounds as if the evaporator fan on this unit is toast. That is also why is it having a hard time maintaining temperature. The temperature indicated is actual air temperature sensed so it will go up and down a couple of degrees above and below setpoint but when operating correctly the product temperature will be very stable.
If the servicer does not fully understand the new digital system, make sure he/she contacts the factory technical assistance rep. at 800-428-6644.
Posted on Sep 15, 2009
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
The light in my Marvel 3BAR cooler does not come on. The unit has power and is otherwise functioning well.
The 3BAR cooler has a 10-inch light bar that has multiple indicasent elements and is plugged in to the ceiling receptacle via a three pin plug. If you have a resistance/continuity tester you can unplug the light and check it for continuity across the two outer pins. (the center is ground). You can can also loosen the two screws that it the assemlby to the ceiling, remove the assembly and carefully test it with power. Most likely, it has burnt out. If the light checks good, then power must not be reaching the recepticle. Power is routed to the recepticle directly from the power cord via the door switch (when open) or from the ON/OFF rocker switch in the toe-kick. I hope this helps.
Aug 24, 2009 | Marvel (6SBARBSG) Wine Cooler
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Jun 18, 2009 | Marvel (6SBARBSG) Wine Cooler
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Marvel 6barbd undercounter fridge
marvel 6sbar-BD with wine storeage racks on the bottom and two glass shelves above. If I put sodas on the top shelf they expode. I have it on the lowest setting. Please advise.
Dec 22, 2008 | Marvel 6BAR-BD Beverage Cooler
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Marvel (6SBARBSG) Wine Cooler Logo
283 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Joseph Hoffmann
Shehu Pro
Shehu Pro
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
