Question about Vacuums
It shut off ,the water got real foamy and it shut off . will it reset. Do I need to reset it.
  • 97 Answers
It should reset, try not using a sol that has a foaming agent in it.
Posted on Jul 20, 2009
I was vacuuming and my vacuum just shut down completely and won't turn back on at all
If your machine has a reset button see if it needs reset. If it does not have a reset button it likely has an internal reset that shuts it off if the motor gets too hot and will reset when the motor cools down. Overheating is usually caused by something restricting the airflow, it could be a clog or the bag is too full or the filters need replaced.
Feb 18, 2017 | Vacuums
Why wont my rainbow turn on?
maybe the reset button tripped need more information on this problem could be many things water shut off system also could have been tripped when water enters certain aeras of this machine it has a system that will prevent it from running
Jul 11, 2014 | Vacuums
My rainbow stopped working while im shampooing
If the water gets to high in the water pan, then the motor will start hitting it and will make it off balance. This will cause the motor to shut off to protect itself. Wait about an hour for the motor to reset.
Our tech. team is available if needed... Contact Us
RainVac
Jun 16, 2014 | Rainbow E series Canister Wet/Dry Vacuum
My oreck rinse-o-matic vac keep shutting off while i'm cleaning. I cleaned the water out and added new, I checked to see if anything was jammed up at bottom. It keep shutting off??
I had the same problem...kept pushing the reset button on the plug, but continued to shut off. Took it to my local electrician, who removed the plug w/reset and replaced it with a regular plug...works fine now. Must've been a short in the reset part...sometimes simpler is better! Cost me $7.00, lots cheaper than a new machine or the $100 repaire quote from oreck!
Mar 18, 2011 | Oreck Vacuums
M&S FX 2000 vacum shuts off
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 08, 2010 | M&S Systems FX-3000 Bagged Central System...
Bissell 9300 will not spray liquid
I've got the 9300. Same problem occured during warranty period. They replaced the pump and it has worked fine since. The service person said never to put hot water in the tank (whish is what I was doing). If you put hot water in the tank, with the heater on, the water gets boiling hot and then the plastic impeller on the pump expands and the pump shaft simply spins and does not turn the impeller. Don't know if it is true or not, but his explanation sounded reasonable. Since then, I have used only lukewarm water in the tank and it still squirts fine (about 2 years). I also shut the heater off and squirt some fresh water in order to keep the pump cooler if I need to pause the cleaning for more than a few minutes. I took it apart one time to see what is inside. The pump is not real easy to get to. Good luck.
Mar 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kirby Shampoo system not dispensing foam
Few possible causes
1. Valve under the sponge (water tank) is clogged. Replacement HERE.
2. Tray is now lowered all the way down.
3. You use non-foamy solution.
4. Carpet is very dirty so foam gets broken up very fast
Hope this helps,
Rocky
Sep 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My vaccum shut off and will not start up.
Does it try? Or is it just totally dead, doesn't even grunt when prodded?
Some will shut off if overheated, and will later start just fine.
Some will shut off if an internal filter gets too clogged and the motor is straining too hard. Open it and clean/ replace any internal filters - often it's just a piece of mesh/sponge in a frame near the motor housing, inside the machine. Remove, rinse, shake off any water, re-insert. Try to start.
If vacuum is the bag style, is there a lever/switch inside that gets pressed when the bag is too full?
For a removable bag, try removing the bag and see if the machine will run for a couple of seconds without the bag present. Of course it might have a sensor and refuse to run if _no_ bag is found... but at least if it did try to run, that would give you a clue.
If it's the kind that has a rug-beater/spinning-brush cleaning head, is there a small (usually red) button possibly labeled "Reset"? What happens if you press that? If no beater head is involved, try looking all over the outside of the machine - and then start opening cover(s) and looking inside for anything like a reset button. Or a fuse. Can't really be more specific. Not a real expert... just spent hours poking around inside my own vacuum for a different problem.
- Inspector Dryfish
Jul 22, 2009 | Euro-Pro NV31 Infinity Vacuum
Over heating?
it sounds like you need to replace the motor in it . thank you for using fixya
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
