Question about Microsoft Xbox 360 Console
The disk drive wont shut on my xbox360
Its not closing its stuck open
    Problem Solver:
  • 8 Answers
Your disk drive shutdown, you will have to open up the xbox, unplug the disk drive then plug it back in.
Posted on Jul 16, 2009
My disk drive wont open help
please use eraser pencil .and put in the small orifice and open it.God bless
Mar 16, 2013 | Computers & Internet
My xbox360 thing that reads the games wont stay closed
all it is ur lens isnt in the correct starting position however its a little annoying when everytime u what a go of the xbox it takes about 20mins to get it to work but now iv fixed it properly well all i did is open the xbox comnpletly and get 2 dvd drive open it up i was shocked wen i opened up mine there was a dog on the lensand all over the whole grease on the bars were coverd in hairs i pulled the lens to the correct starting position and clean the dvd drive a best as i could amnd now it work perfect
this will fix it because over time this method will take longer and longer trust me 3rd xbox
Mar 19, 2010 | Microsoft Xbox 360 Console
My xbox disc drive keeps opening and closeing and wont let me play games
you will need to open this drive and clean the drive belt, or the tracks the tray use as they may be gummed up and dirty.
Open tray error is common, even more so on Samsung drives.
To fix this you usually really need to open your xbox360 so you can get to the disk drive so you can open it for a self-service. BUT first try to fix it with a laser cleaning kit, they don't cost much to purchase and you can get them from most electronic shops and also eBay.
If a cleaning kit did not work, then the problem may be your tracks, the disk spin head or the belt that moves the tray (drive belt).
Once you have your xbox360 opened (lots of good video guides on YouTube on how to open the xbox360) you will have to open your disk drive.
When its open, clean the left and right tracks, they can get gummed up with dust, and even tar if the unit is from a smokers home, when the tracks are dirty, it can stop the tray going in all the way then games don't play. Also if the spin head is dirty (the plate the disk sits on to spin the disk) then it does not grip the disk fully and thus does not spin at full speed, giving you read error. Finally the belt inside the drive can be removed and can be boiled in water for a minute or to, this cleans it and brings it back to its original shape, this helps the belt regain lost grip and can also fix this error your having, but belt problems are more for Samsung drives.
You should use rubbing alcohol to clean the internal components of your drive without causing any damage, you could even clean the laser yourself using a high quality kitchen roll sheet or micro fiber cloth, with rubbing alcohol and gently pass it over the lens to clean it. Once you have done all this, close everything back up and see if the problem is gone.
If your still having problems then chances are you need a new laser for your drive.
The following YouTube video may help you http://www.youtube.com/watch?v=6GLS1dndQLU
Let me know if you need more help.
Jan 02, 2010 | Microsoft Xbox 360 Console
Disk drive door stuck, won't close.
if your warranty is already voided then you could try openning up your xbox and then openning up your dvd drive and just see what its getting jammed up against
Jul 29, 2009 | Microsoft Xbox 360 Console
Old xbox360 disc tray wont close at all
open it up ( very carefully) and check to see if the disk tray end is still attached or alligned to the plastic gears that eject the tray. if so check the rubber band to make sure it has not broke or streched.
Jun 25, 2009 | Microsoft Xbox 360 Console
Drawers wont open or close.
I will assume you are talking about the CD/DVD drive drawer.
Get a large paper clip. unbend it part way and use the straight end to push the drawer out using the little hole located on the front of your drive.
You may have a stuck disk in the drive.
Mar 19, 2009 | Dell Computers & Internet
My xbox360 wont play any disk
I had a problem like this a few days ago, my 360 had problems reading my disks. I ended up opening it up and cleaning the laser in the dvd drive. After that it played fine, if that doesn't work you might need a new dvd drive.
Jan 04, 2009 | Microsoft Xbox 360 Console
My xbox 360 cd drive keeps on opening and closing.
Your having a dvd drive problem Im taking a guess but i have fixed many like this before. What you need to do is take your xbox360 apart. You can find a video how to do this on our site http://www.xboxmodshop.com next you want to remove your dvd drive take out the four screws on the bottom and remove the top cover. Now make sure your looking at the spindle where the game rest in the middle of your spindle you will normally find two magnets, but in your case your probably wont. Yours are probably stuck to the top of your drive cover. You need to remove them and superglue or epoxy them back in the middle of your spindle.After completely dry put everything back together it should play normal.I recommend a inter-cooler so this wont happen again.
Thanks http://www.xboxmodshop.com
Oct 11, 2008 | Microsoft Xbox 360 Console
Xbox360 drive wont close
It is probable that the cd drive motor is fryed. If it is still in warranty you should return it.
Aug 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
190 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
