Question about LG KC910 Renoir Cell Phone
Hey, I'm trying to connect my phone to my pc through USB and bluetooth, but it won't do it. When I try to connect through USB it says "Failed to connect phone to PC" When I try to connect through bluetooth, it says that the password thing doesn't match. It's really frustrating me, and any help would be much appreciated.
Hi just had this same usb problem... heres what idid.
first install lgusbmodemdriver(from disc i think)
then connected phone, click pc suite on phone (mine is set to always ask)
then went into device manager, found 3 entries with exclamation mark....reinstall drivers for all 3 letting windows do it automatically.....
i then tried pc suite again and presto....it works!!!
good luck!
Posted on Jul 26, 2009
Hey! i have the samsung m8800, i'd like to transfer pictures from my phone to my laptop unfortunately the phone won't connect via the usb cable!! however i did ring an advisor and she told me to install...
Hi, your phone should also have bluetooth. I suggest you turn this feature on under the phones settings and on your computer. Then make sure both devices are on discoverble mode. Try to set the phone up as a new bluetooth device on your computer. Once the pairing is completed you should be able to transfer files wirelessly.
Mar 14, 2011 | Samsung B3410 Cell Phone
My nokia 2680 did not detected by my pc althou it is connected with a usb data cable. what should i do to transfer my videos and photo's from my cellphone to my pc?
Sir/Maam,
Have you tried using other usb cable? or using other usb slot?
try using other cable or usb slot, it can be that the problem is in either one of them.
To transfer you files from phone to pc without using a cable, you can use the bluetooth technology. You can buy a bluetooth for your pc then send your files thru it.
Or if your files in the memory card, you can just buy a card reader then use if to get the files you wanter. The memory card will only act like a flashdisk.
Hope i helped you, thanks.
Feb 27, 2010 | Nokia 5310 Cellular Phone
I can't backup my 6300
try a different USB cable or try the bluetooth to connect to your PC.
Jul 27, 2009 | Nokia 6300 Cellular Phone
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Can connect my samsung behold t919 to computer
GO TO MENU SETTING SELECT PHONE SETTING THEN GO TO THE USB SETTING THEN SELECT MASS STORAGE PUT THE USB IN THE PHONE. THAN SWITCH THE BLUETOOTH. THAN IT STARTED TO LOAD UP. IT WORKS FOR ME I JUST TRY IT.
May 14, 2009 | Samsung SCH-a650
Bluetooth connection to my LG Renoir KC910
Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
Look at phone enter same code, 0000, when prompted and hey presto all will work.
Hope this helps
Regards
Max
May 01, 2009 | LG KC910 Renoir Cell Phone
Cant connect my g700 to pc via usb
I experienced this problem also because I used the same unit. I installed it via USB directly to my PC then after installation was done, i failed to view my files. Then I tried to buy a memory card. Together with the memory card inserted in my unit, I already viewed my mobile and memory files.
Mar 15, 2009 | Sony Ericsson G700 Unlocked GSM Smartphone...
I HAVE LGKG195 AND WHENEVER I WANT TO CONNECT MY MOBILE TO OTHER SETS FOR RECIEVING DATA THROUGH BLUETOOTH THE CONNECTION FAILED. PLZZZZ HELP ME OUT. PLZ SEND THE SOLUTION TO MY EMAIL-ID...
hey buddy
problems can be 2
  1. your bluetooth has become faulty get it repaired free of cost if it is under warranty
  2. the set you are trying to send data to is low on phone memory release some phone memory on that phone and then try
pls rate my solution
regards
Feb 19, 2009 | LG KG320 Cellular Phone
Connecting to internet via pc
hey buddy,the problem of airtel connection starts with the settiongs on ur phone to surf...messge all to 222 for settings..after settings reboot the phone...after that..don browse on phone first...connect the usb then using sony tools connnect to net..
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Sony Ericsson K750i Cellular Phone
LG KC910 Renoir Cell Phone Logo
281 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
