Question about Motorola Radio Communications
Radius CP200 is in monitor mode I think and i can't get it out of that mode by pushing the programable buttons
  • Motorola Master
  • 1,654 Answers
Your programmable buttons can be programmed to a number of options. Typically the first button is programmed to monitor and sticky monitor. If this button has been held in a long press you can clear the setting by holding it in another long press to shut it off, or by simply shutting the radio off and turning it back on.
Your second programmable button could be set for an number of features, but like the above description, simply pressing it again or shutting off the radio will turn the feature off.
When you refer to Monitor Mode, we assume your are indicating the radio is operating open squelch, with no private line code. This is when you can hear ALL transmissions on your frequency. If this does not describe the problem you are having please repost another question.
Posted on Jul 16, 2009
My radio (new) receives but will not transmit, should I return it?
That depends on you. Are you happy that you received a device that isn't fully functional?
Aug 21, 2014 | Motorola Radius Cp200 - Two-way Radio Uhf...
Why motorola radius cp200 flashes red while charging?
Typically when the charger flashes red you have one of the following conditions:
1) The battery is simply too low to charge. Leave it on the charger for a few hours to see if it resolves. If it is a new battery return the battery for a replacement.
2) Your battery is not making good connection. Clean the battery and charger contacts with a pencil eraser. Check your contacts in the charge itself to make certain one isn't damaged or broken.
3) Your battery has an internal short. Test the battery on another charger to see if you get the same result. If so, replace the battery. 4) If you have a charger problem, the best test is to try another battery in the charger. Reminder: be certain the insert is turned the correct direction for the battery you are using.
Best regards.
Apr 30, 2014 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Cp200
can you increase the volume? did you try the morse code button beep beep? are both units on? 10-4 big daddy truck nuts Over and Out
Mar 22, 2014 | Radio Communications
Is Radius cp200 compatable with rdu2080d
If your model number starts with AAH50R... the answer is yes. The CP200 could be programmed to match your RDU.
Jan 30, 2014 | Motorola CP200 Two Way Radio
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
ONE OF MY CP200 RADIOS HAS A STEADY SQUELCH SOUND ON ALL 4 CHANNELS, HOW CAN I FIX THIS?
One possible problem is a bad battery. Try swapping batteries with a known good unit and see if the problem is solved. If it is not the battery, then your radio is likely in need of repair.
Best regards.
Nov 09, 2012 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Compatibility
If your CP200 has a model number beginning with AAH50R it can be programmed to match the RDU2080d. If your CP200 model number begins with AAH50K, then the answer is no.
The letter R in the model number indicates it is UHF, and on the RDU2080d, the letter U in the model name indicates it is UHF. Both of these radios are programmable, and could be reprogrammed to match one another, if both UHF.
Best regards.
Sep 20, 2012 | Motorola CP200 Two Way Radio
My Motorola Radius CP200 has lost all channels that was set by dealer is there a way to reset back to factory settings?
It is seldom a CP200 loses frequencies/PL code settings. It is more likely the radio has a bad battery or another issue. The only way to reprogram the radio is by taking it back to a Motorola dealer, as they are all dealer programmable only. Sorry.
Best regards.
Dec 18, 2011 | Radio Communications
Radio Communications Logo
292 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
