Question about Gateway 450ROG Notebook
CMOS battery Gateway 450SX4 notebook
Hi, I need to replace the CMOS battery on an older Gateway 450SX4 notebook computer. Can you tell me how to locate it and what I need to do to access it (e.g., remove which screws, etc)? Thanks. Jim
    President:
  • 1,383 Answers
It is in back sdie of alptop.
You have to remove 4 screw on each side of square.
then you find motherbord chipset.
cmos cell is fixed on motherbord circuit.
Posted on Jul 16, 2009
Drivers
Gateway support site for starters, and then Windows Update, and finally look up components in hardware/Device mgr. Go to the mfrs websites and download the most current ones for your hardware and operating system. If you have an Intel processor, Intel's site "Support" will scan and determine the newest Intel drivers for you. NVidia and AMD's ATI also have drivers. Realtek also provides them for their products.
Jun 03, 2014 | Gateway 450SX4 Notebook
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
I am trying to restore my gateway 450sx4 to the way it was when it came out of the box? the recovery disks are not working.
Are you booting from the Disk. If not make sure the CMOS looks at the CD /DVD drive first so it can boot from it.
Nov 08, 2009 | Gateway 450SX4 Notebook
Gateway 450SX4 512MB max
Go to the gateway site, and select the option to allow gateway to tell you about your machine. It will tell you maximum ram capability
May 01, 2009 | Gateway 450SX4 Notebook
Need to replace the cmos battery on a gateway 450sx4 laptop.
Some are way deep inside, and you have to remove the top part of the case from the bottom.
Some others, you can remove the top power strip, (unscrew screws in the battery compartment, and sometimes on the bottom) and then unscrew the keyboard, and when you remove that, sometimes you can get right to it.
The only problem is, some of the laptop batteries are odd ducks, and not just the standard, they have wires or a metal tag on them. You can always order a new one onces you get to it.
Apr 12, 2009 | Gateway 450SX4 Notebook
Laptop starts and after a few seconds shuts down
Could be overheating, or possibly a motherboard gone bad. Try taking the battery out, unplug from power cord, hold down the power button for 20 seconds, put battery back in and see what happens.
Jan 20, 2009 | Gateway 450SX4 Notebook
Gateway 450rog cmos battery
The CMOS battery is located on the motherboard, just under the bottom left side of the keyboard, by the letter 'V". It looks like a clock battery, marked 3V (volts). The battery comes out of its "cage/connector" by gently lifting it with a small flat screwdriver. Replacement CMOS batteries are inexpensive and readily available at any computer shop. Hope that helps
Mar 15, 2008 | Gateway 450ROG Notebook
I want to disassemble Gateway 450SX4
Nowhere: Only HP and IBM and DeLL offer parts schematics for their laptops. But if you take a look at some of those,you'll have a really good idea how to work on your Gateway,because they're all very similar.
Mar 07, 2008 | Gateway 450SX4 Notebook
Gateway 450ROG Notebook Logo
1,084 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
