When i start my PC it shows Media test failure : check cable after that Operating system not found. I checked all the cables nicely then also I cant open it.
HI there,
The "Error" texts saying:
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel Boot Agent.
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system. "Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Sounds like it could be a bad hard drive. With your laptop turned off, take out the hard drive and put it back in and make sure its nice and snug.
Then go ahead and turn on the laptop and see if you can boot back up into windows.
If you can't get into windows and you get the same message then boot up the laptop and go into the BIOS by pressing F2. When you get into the BIOS look and see if your BIOS is recognizing the hard drive, if it's not seeing the hard drive then that means your hard drive is bad and would need to be replaced.
If your hard drive is showing up then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your recovery cd's.
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
