Question about LG enV VX9900 Cellular Phone
Jawbone won't turn on
My jawbone won't turn on. It there anyway to fix this?
How to pair an aliph jawbone to my phone
turn the bluetooth option on from your evo and make sure that the bluetooth is discoverable and that press & hold down the power button on the jawbone bluetooth till you see lights blinking red & blue or its blinking red only on some jawbones , that check your phone , it should show u a jawbone bluetooth discovered on device than hit connect or pair , enter 4 zeros (0000) to connect & you should be able to use it like a champ , good luck , thank me if i help out on you Question
Feb 02, 2012 | HTC EVO 4G Sprint - /
Need operating manual jawbone thinker
Here is the Jawbone support site. They do not offer a manual on the site. Hope this helps Fix Ya up.
Aug 05, 2011 | Aliph Jawbone Bluetooth Headset
How do you sync a motorola droid with a jawbone
Have you tried shutting the Jawbone off, hitting scan for devices on the Droid, then holding the connectbutton(long thin black button) on the back at the same time time you turn the Jawbone on(Black and blue sliding switch)? This is the only way mine will find and connect to my Jawbone!
Mar 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
Can't connect my jawbone with my phone
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY! "
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Cannot pair lg voyager with jawbone bluetooth.
Mine wouldn't pair either so I went to the jawbone site and I did this and it worked the first time.
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
Mar 22, 2009 | LG VOYAGER VX10000 Cellular Phone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
Lg 8700
After a while, the battery becomes slightly loose, so battery connection is intermittent. Simply put a small wedge (small piece of cardboard) at the top of the battery compartment, so that when you renisert the battery, it forces a tight connection on the bottom connector. I have fixed 5 phones this way. Intermittent connection causes the blutooth to drop, and battery to appear to not hold a charge well. THIS IS SO SIMPLE, yet nobody knows about this! It's worked on EVERY VX-8700 I've tried it on.
Feb 14, 2008 | LG VX-8700 Cellular Phone
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
LG enV VX9900 Cellular Phone Logo
1,685 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
