Question about Dryers
My Amana dryer model number LE7153WM does not heating
My Amana dryer model number LE7153WM does not produce heat to dry clothes. It was working fine a couple days ago. I checked the variable temp control knob and it is set to med-high moved it to high but no heat. What do I check next?
    President:
  • 1,776 Answers
The thermal fuse and the heating element would be the likely suspects. Both can be checked with an ohm meter. If there is no continuity, it indicates a defective component. Neither is repairable and if either component is bad, it will have to be replaced. Hope this helped. Good luck.
Posted on Jul 16, 2009
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
LE7153WM- Runs but does not heat. Coil is not "open". what do I check next?
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Amana Dryers
We have an Amana distinctions dryer model
you need to replace the thermostats on the element.
Oct 24, 2009 | Dryers
Does not produce heat to dry clothes
The ehating element is relatively easy to replace. You should be able to find a scematic wiring diagram in the owners manual. If you dont have one check on line they may have one on thier web page. While you are doing this go ahaed and check your master thermal fuse. It will be depicted onm the diagram to. The fuse is usually the cause.
Apr 27, 2009 | Dryers
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Maytag Performa Electric Dryer, model # PYE2200AYW.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Oct 18, 2008 | Dryers
Dryers Logo
237 people viewed this question
Top Dryers Experts
