Question about Canon Office Equipment & Supplies
Canon IR C3200 Out of registration. When i print out a test print the colors are all out of sink and not lining up on top of one another. was running fine and then it started having this problem
Clean the IBT ***. use IPA & aliment
otherwise you can change IBT OR
+91-9974010024 dial for
more solution
Posted on Jun 28, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
The cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing
Posted on Jul 16, 2009
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
Need How-To on calibrating Canon IR-3200...
try under user mode (add.function) cleaning or similar and auto calibration, it will print out 4 test that you need to scann on copier, you just follow the copiers instruction
Sep 14, 2009 | Canon imageRUNNER C3200 Color Printer
Canon imageRunner 3200n printing problem in color
ok you are in the right area are you taking the belt off to clean those rollers???? if not do that 1st. then you may have to clear the dc controller but 1st do a DPRINT under the service function menu. after the dccon clear you will need to put those #s back in
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
Color printing problem printing in double image looks there is registration problem irc3200 canon
this is allmost allways the transfer belt assy if you have over 200k on the machine the belt is slipping ever so little. you can take out the unit and remove the belt and clean all the rolles esp the largerer drive one. seen this many times
Dec 23, 2008 | Canon imageRUNNER C3200 Copier
Canon ir c3200 promts for page setup on each internet document
I believed when page setting box show out you have to enter the quantity you want print
Dec 09, 2008 | Canon imageRUNNER C3200 Color Printer
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Colors are off registration
this problem can sometimes cause by uncalibrated machine upon replacement of major parts such as assemblies. or parts related to fusing, developing of drum related parts
mis registration of colors can appears if you machine isnt calibrated nor cleaned correctly, try going throug a resetting or set up procedure from your maufacturers manual
this would surely resolve your problems
Jul 14, 2008 | Canon imageRUNNER C3220 Color Copier
Error Code
Called local service technician.
Mar 26, 2008 | Canon imageRUNNER C3200 Color Printer
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Registration problem
ADJUST REGISTRATION ON THE PCB BOARD AND ALSO THE BIAS VOLTAGES
May 13, 2007 | Canon imageRUNNER C3200 Copier
503 people viewed this question
old marine
old marine
