Question about Microsoft Xbox 360 Console
Tray was stepped on and is not not attached to
Tray was stepped on and is not attached so there is no way for the game to enter the system can it be fixed
  • 27 Answers
Sending it to microsoft would be fine, but no need to buy a new one if that fails, you should open up your console(they have you tube help vidoes) thenbuy a broken drive off ebay with a good tray. make sure its the same brand drive though, theirs the hitachi, ben-Q, and samsungs. then just swap trays. better than payen 200 for a new compared o $15 or so.
Posted on Jul 18, 2009
    Problem Solver:
  • 8 Answers
Yeah.... either send it to microsoft or buy a new xbox.
Posted on Jul 16, 2009
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
Aug 20, 2014 | Microsoft Xbox Video Game Consoles & Games
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
3151-3cd6-b800-0402-c000-0001
Your console had a problem during the update process. Carefully follow these steps:
Remove any disc from the console.
Leave the disc tray open.
With the disc tray open, remove the power cord from the back of the console.
Plug the power cord back into the console. Do not turn the console on yet.
Gently push the disc tray about half-way back into the console.
Push the power button on the console.
Important: Do not use the controller button or the disc tray eject button to turn on the console for this step.
The update should now continue. If the above steps do not work, the console might need to be repaired. You will then have to contact your local phone support.
Jul 21, 2017 | Microsoft Xbox 360 Console
Default pin
Hi Dawn,
The default pin is usually attached to your router. If you don't know where to locate that, use the following steps:
  1. Enter 0000. This is usually the default pin.
  2. If that doesn't work enter in a bunch of numbers. After awhile the system will provide you with a reference number and a Nintendo phone number that will fix your problem.
Hope that helps!
Feb 09, 2012 | Nintendo Wii Console
I take 7 or seven time putting the disk in and out before it reads a disk has happen since the first day i had it.
tip:read thease steps before startting
step 1:make sure there is no game in the console.
step 2:turn off your console.
step 3:take off the HDD from the top of your 360.
step 4:turn on your console.
step 5:make sure your disc tray is open.
step 6:put the HDD back on.
step 7:whilst the screen is black put game in tray and close the tray.
step 8:repeat thease steps until the game works
(it should take about 2 trys)
Jan 16, 2011 | Microsoft Xbox 360 Console
Xbox 360 freezing
hi,is this also happening with other games? if
YES try this steps
1.clear system cache but make sure that there is no disc inside the disc tray
(go to my xbox then system settings,then memory,check how many devices you can see,if one highlight the storage device then press the Y button you will see an option for clear system cache select it and when prompted please select yes,don't worry it will not erase any of your profiles and save games) test the game discs if still not the next step is
2. removing of the the hard drive
(if you are using the original xbox the hard drive can be found at the top of the console when you positioned it upright, but if you are using Xbox 360S,positioned your console like a DVD player on the right side of it check for grill that is different push it then pull you will see a ribbon that ribbon is attached to the hard drive pull it NOTE:some xbox360s does'nt comes with a hard drive) once the harddrive is remove try the game discs again if it works this means that your hard drive cannot be detected by the console,try again playing the game with the hard drive(reattach the harddrive to the console)make sure you hear the clicking sound,if it works then it only means that the hard drive is not properly placed. but if not the hard drive failes.check if the console is still under warranty so that microsoft can replace it,but if everything fails do the next step
3.make sure that there are no memory units or USB/thumb drive attached to the console and this the game disc
4.check the region code of the game or if the game works before with your console,if you have other console try the game disc with the other console if it works,i hate to say but you have to send your console for repair,contact microsoft for repair
I hope i provide you the solutions...thanks
Nov 30, 2010 | EA Sports Video Game Consoles & Games
My ps3 does not load games or movies, screen stays still with the circular load symbol at the the top right corner, anything i can do at home to fix this?
Try this:
Mar 25, 2010 | Video Game Consoles & Games
My xbox keeps saying open tray when i have my game in the tray. What do I do to fix it?
Here are some common troubleshooting steps you can try to solve this issue:
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked.
if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Please do comment on this tip if you find it helpful, Wish you a Happy New Year and Happy Gaming
Regards
KreativeGeek
Jan 31, 2010 | Microsoft Xbox 360 Console
My PS2 slim console takes forever to load between game scenes, Is there something I can do to speed up the game?
Dear Sir!You should increase the disc speed.Follow these steps to increase the disc speed:
Step 1>>Turn on your PS2 without inserting any disc into it. Step 2>>Wait for the main menu [Containing Browser and System Configuration ]. Step 3>>Press Triangle Button to enter Version Information menu. Step 4>>Move the cursor to Play Station Driver and Press Triangle to enter Play Station Driver menu. Step 5>>At PlayStation Driver screen, Press x at Disc Speed and set it to Fast. Step 6>>Enter game disc and enjoy.
Hope that solves your problem.Good Luck!
Jan 10, 2010 | Sony PlayStation 2 (PS2) Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
