Question about Car Audio & Video
Peugeot 406 radio led lights not working, checked the 5amp fuse in back of radio, also 10amp under fuse box, when side lights on still no LED can you please advise.
  • 11,896 Answers
Check to see if the dimmer wire is connected to the back of the player. It is usually orange. See if it is connected to your car. If your car doesn't have a dimmer wire, you may need to hook it up to light switch dimmer or other power source.
If the wire is already connected, it may be a faulty capacitor inside the LED of the player
Posted on Jul 16, 2009
Which fuse controls the dashboard lights
Central junction box - under dash , right or left side ?
f2.04 - 5amp , f2.20 - 10amp , f2.13 - 5amp , f2.17 - 5amp , f2.19 - 20amp
Aug 19, 2015 | 2002 Ford Thunderbird
Peugeot faults washers dont work
you have to check the fuse box under the wheel
Jul 07, 2014 | 1999 Peugeot 406
Fiat 500c stuck in "phone"mode. How do I reset so the audio works?
With the key off, remove the radio fuse from the fuse box, start the car (there should be no power to the radio if you got the right fuse pulled), turn turn the car off, then then put the fuse back in. That should reset it.
In my 2013 Fiat 500 it's the 3rd fuse up from the bottom, on the left side of the bus. 10amp, red fuse. (If you're unsure, use the web to look up a map of the fuses for your make\model\year. Don't justt start unplugging fuses... you may strand yourself.) -Good Luck!
Jun 05, 2013 | 2012 Fiat 500
Instrument cluster,radio,and no rear parking lights
begin by checking all you fuses on the left end of the dash, if all the fuses are ok you will have to write back. what led up to this problem? ex:car got jump started backwards! hint: the radio fuse and inst cluster fuses are on the left end ,the tail lamp is under hood fuse box,also check if the dome light and glove box light are working
Oct 12, 2011 | 2001 Dodge Ram 1500 Truck 2WD
The cigarette lighter connection no longer works in my Peugeot Estate 406. Now I need it for my new satnav. Any suggestions?
  • There are two fuses that go to the cigarette lighter. Look for the blown one or replace one and then the other just to make sure.
  • In the passenger compartment fuse box look for -
  1. Fuse F1 - 10Amp - ACC+
  2. Fuse F1A - 10Amp - Batt+
  • Hope this helps and thank you for using FixYa
Regards, Tony
Jun 14, 2011 | Peugeot 405 Cars & Trucks
Radio not working were are the fuses all fuses
Left side engine compt fuse41-15Amp.Left side of dash fuse11-5amp.Fuse12-5Amp.Fuse3-20Amp
Aug 30, 2009 | 2006 Ford Explorer Sport Trac
Radio Not Working
There are 3 fuses in the interior fuse panel that feeds radio.
no. 11(10amp) is ignition switch power to the radio it comes into radio on the TN/LB wire.
no. 27 (10amp) is hot at all times and comes in on OG/LG wire.
no. 12 (5amp) is hot in run or accessory and comes in on YE/BK wire.
Check these with 12V test light at fuse and at radio connector.
Mar 11, 2009 | 2001 Ford Escape
Cant find fuse for my radio in 05 Taurus
There are several fuses to check. 2 fuses to rear control unit are in the battery junction box(underhood fuse panel) are no. 27(5amp),no. 17(20 amp). In the interior fuse panel 3 fuses to the intergrated control unit are fuse no. 32(10amp),no. 33(15amp), and no. 22 (15amp).
Feb 26, 2009 | 2005 Ford Taurus
Cigarette lighter fuse peugeot 406
fuse box under the steering wheel .. check fuse F23!
Feb 04, 2009 | 1990 Peugeot 405
Car Audio & Video Logo
527 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
