Question about Samsung L100 Digital Camera
Lens doesn't come out anymore
I have Samsung L100 digital camera. My toddler did something to it (didn't drop it), probably pressed on the lens when it came out and pushed it back. Now the lens won't come out and when I turn the camera on, it makes a sound. Any idea if it's serious and how to fix it. Thanks !
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Posted on Feb 12, 2013
2 Suggested Answers
Kensolutions
  • 455 Answers
SOURCE: Hi. I have a Lumix
I'm sorry to know that the Camera Lens is not focusing and retracting. I'll be glad to assist you with this. I suggest that you perform a power reset of the Camera and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If you're able to access the Menu of the Camera, then reset it back to factory reset and check if it helps. Press the MENU button, press the Right Arrow button and select the SETUP Menu of the Camera. Now press the down arrow button to select RESET. Resetting the Camera will change all the settings to factory default.
Performing the steps should resolve the issue.
Thanks for using FixYa.
Posted on Jun 26, 2011
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
My samsung L100 will let me view pictures on my camera but not take them whys this?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 20, 2010 | Samsung L100 Digital Camera
Samsing M100 Digital Camea Lens not working
May be some dust particles are stuck. use the vacuum cleaner to suckout the dust from between the bady and the lens casing. Suckout and not blowin.
Aug 24, 2009 | Samsung L100 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery...
Most probably the lens problem, it got stuck or it's damaged. Try to gently pull out the lens to see is it only got stuck or take it to service
Jun 23, 2009 | Samsung L100 Digital Camera
I dropped my camera now the lens wont come out
Buy a new one, its broke and not worth the price of repair, I did the same thing...
May 29, 2009 | Samsung L100 Digital Camera
Problem with samsung L100
Ok, hello everyone who has bought the walmart camera ( im sorry it is not working ). The camera is designed with a sensor that detects if the lens is fully closed or not, now this may sound wrong to you but all that must be done is push that lens back into the camera, while you press the power button ( release as soon as you feel the the motor gearing up and you wil be ok) this solution works for most Samsung cameras, although the lg100 is what i just tried it on like 5 seconds ago. Also what this is from is a low battery or something actually wrong with the camera itself. The low battery cannot close the lens all the way.
Hope this helps, oh yeah wickedbadawesome.com = . thats me ( when i get that dumb site up and finished check it out)
Sep 09, 2008 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
