Question about ASUS A8N-VM Motherboard
I have somehow corrupted/lost the cd/dvd drivers for this machine running XP Pro. have now installed a SATA DVD-RW. Windows finds it but cannot install drivers. Can I get these from anywhere?  A8 VM Motherboards
  • nickjwhite Jul 16, 2009
    Sorry, I have I-tunes installed and have reinstalled and that didnt resolve the problem.
    The olf Pioneer IDE DVD drive, I have now taken out, and installed a SATA DVD-RW. Windows finds the new hardware, but fails to install any drivers, saying they are corrupted. Do I have to do something special with a SATA drive?
  • nathan May 11, 2010
    make & model of DVD drive?
    Brigadier General:
  • 10,406 Answers
Download/install Apple iTunes.
It loads a driver for CD-drives.
Reboot, and your CD-drive should work.
Posted on Jul 16, 2009
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
Not able to burn DVDs to DVD R or DVD RW using Nero essentials and windows xp pro
Uninstall nerro>go run > type >%temp%> delete every thing>restart>again Install the nerro .
If does it same please open the the pc cover .Fit cable tightly /or change the cable as new.It is better to change as new. go bios set the boot sequence>1st cd and 2nd hdd.
if it same problem any how open the cd/dvd rw after switch off the pc poower .cleane its lance surface .just we should brush our teeth frequently.
Nov 28, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Installing windows xp on an IBM X-3200 machine
    power off the server
    connect the SATA HD direct to the sata connector on the motherboard.
    turn on the server with XP CD and use the drivers on servers DVD companion
    download LSI controller driver for XP and Intel chipset from the web and install, once the controller are set power off the server.
    put the SATA HD back on the SATA Bays (Server front)
    Turn on the server and DONE!!!
    May 30, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
    My samsung cd rom sc 148c is not working i am getting this message under properities Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) i have...
    If it's not a SATA drive try to set your IDE Controller in Device Manager to use DMA mode not the PIO. If it won't help try to find updated firmware for your drive and install it. Read Carefully Installation Manual Before! If it won't help that's a sign that your PC wants you to upgrade it with DVD/RW instead.
    Good Luck!
    Apr 17, 2009 | Samsung SC-148 CD-ROM Drive
    I can't downgrade Vista to Xp
    You can install windows XP.
    First go to BIOS and change sata mode to IDE mode
    or option to disable SATA Native mode
    then choose mode to IDE or disable SATA Native mode
    then install windows XP
    If there is no option about change sata mode in BIOS.
    You should insert ahci driver to Windows XP CD using nLite
    read this
    http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
    you can use this driver
    http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
    Or you can install windows by inserting driver when setup prompted
    To install Windows XP with native SATA driver, perform the following steps:
    Boot the notebook PC.
    Insert the Windows XP installation CD into the optical CD/DVD drive.
    Press the F6 key when prompted
    Press the S key to specify the additional device.
    Insert the SATA driver disk into drive A. (using floppy disk drive)
    Follow the on-screen prompts.
    Or if both way is cannot be done
    i have the third way
    use an unattended XP installation disk
    you can download it from here:
    http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
    after you download
    burn the CD image to the CD/DVD
    then install XP using that CD/DVD
    Jan 24, 2009 | Compaq Presario C700T Notebook
    Dvd not seen by XP
    plz check the manufacture website for the drivers
    Dec 09, 2008 | Microsoft Windows XP Professional With...
    My dvd rw is not detected
    Sounds like you need your manufacturer's SATA drivers.
    This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
    If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
    This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
    Aug 20, 2008 | Microsoft Windows XP Professional With...
    Windows XP not recognizing cds/dvds in my HP DVD640i
    Most likely your CD-DVD burning software is corrupted. When that happens, the machine doesn't recognize the existence of the CD/DVD hardware. Clean up your machine, defrag, run a freeware registry cleaer-defragmenter (see C-net for a good one). Then Reinstall/upgrade your burning software (the Windows XP software is not sufficient) either from HP/Compaq, if it came with your machine, or the program website if you purchased it separately. You may find out which it is by using a marvelous freeware program called Belarc advisor.
    Feb 11, 2008 | HP LightScribe dvd640i (DVD640I)...
    When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
    Aug 20, 2007 | Microsoft Windows XP Professional With...
    ASUS A8N-VM Motherboard Logo
    124 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
