Question about National Little Tikes Hummer Yellow
Where can i find a battery charger? can i use a conventional battery charger?
    Champion:
  • 254 Answers
Try Toy R Us
or Walmart
atdlee@netzero.com
Posted on Jul 16, 2009
We have a new chair and where saving it as a back up. it sat for about 3 months and we didn't charge it. now we hooked up the charger and only the green light is on nothing else. whats going on?
the rechargeable battery requires regular charging or at least matainace charging if it is left for long periods, the battery is always dissipating even if your not using the item but it is connected, it has probably gone to such a low point that it is now unrecoverable, try removing the battery & charging with a conventional high powered charger to boost it back to life, if it wont charge its had it.
May 09, 2015 | Health & Beauty
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Is the 1970 cb 100 honda a 6 volt or 12 volt system
It is possible for cells to go bad in a battery. Anything that remotely resembles mold in a motorcycle battery is not mold, but it is bad news.
It should be a 12 volt system.- 6 fill caps on conventional batteries.
Dec 17, 2012 | 1970 Honda CB 100
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
Turn key...nothing.....radio...ac....lights work....is it my starter?
If there is nothing, you probably have a dead battery-nothing else would cause no crank/lights or accessories unless it was a bad connection at your battery terminals. charge the battery with a battery charger ) a 2 amp charger would take a couple of days, 10 amp about 8 to 10 hours and a 50 amp about 3 hours, but charging slowly is better for the battery)- If you have a voltage meter, chances are your battery is well below 12 volts, and as it sits it should recover somewhat, but probably you will still need to at least charge it. Conventional batteries do not do well with full discharges and it can 'kill' even a fairly new battery in short order, so prepare for the possiblilty that you need to replace it.
Jul 04, 2011 | 2000 Chevrolet 3500
2006 Buick Lucerne/ 10 mo.dead battery told i need to put 1000 ml. a mo. to keep battery????
That is not necessarily correct-if the car sits all the time, parasitic drain on the battery will eventually kill even a new battery. Telling someone that a car has to be driven 1000 miles a month to maintain the battery is not a solution-if you don't drive alot, get a trickle charger ($good one is $30, one that works can be found for $10) that you can plug in and keep hooked up to the battery to keep it fresh. Another way is to get a solar panel charger (1 1/2 watt, about $20 at Harbor Freight) and put the panel on the dashboard, and the other end into the cigarette lighter socket in the dashboard. A third solution is to buy a deep cycle battery (Optima) that can be fully drained hundreds of times yet will recover and work properly-these are expensive ($175), but out perform conventional batteries that die if fully discharged a few times. You could also install a remote starter and periodically start the car, letting it run for 15 minutes-about $200
Jan 25, 2011 | 2006 Buick Lucerne
Hello , i got and old MAXI MOUSE PORTABLE SPEAKER/AMP and i lost my CH-40 charger, do you know how i can get a new one or something similar. i live in Sweden
hello, if you also have 230V in sweden then look at your electronic supplier for a: Input AC 230V/50Hz/90mA/21VA Output: AC 22V/520mA/11,4VA
that's written on the charger.
Sep 23, 2009 | Audio Players & Recorders
National Little Tikes Hummer Yellow Logo
317 people viewed this question
Top National Toys Experts
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Vernon Taylor
Are you a National Toy Expert? Answer questions, earn points and help others
