Question about Jandy Aqualink Rs4 One Touch Control System Control System
I need help with aqualink rs4 i turn on the spa and the spa heat but have to go to the heater and hit temp control up button to get heater to come on
  • 128 Answers
The heater is not wired to control panel for automation operation
Posted on Aug 23, 2009
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Aqualinks RS4 pool light button will not turn off. Has 6522 REV 1 on screen
bad light relay what ever aux it is replace it it is stuck on you can turn off breaker for light in temp fix
Oct 10, 2010 | Jandy Aqualink Rs4 One Touch Control...
My indoor RS4 panel says the spa is heating, and then reached 101 degrees. But when we got in, it was only 97 degrees and the outdoor panel displayed 97 degrees. Everything else seemed to be working fine.
If the heater is set to 104 then this is probally your Aqualink temp sensor. This is mounted in a pipe with a stanless steel clamp holding it in place. If you follow the wire back to the controler box it just unplugs and the new one goes right back in. Easy to do and the part is inexpensive.
Sep 26, 2009 | Jandy Aqualink Rs4 One Touch Control...
Spa only gets to about 90 deg
For a quick fix you could swap out the air and water temp sensors. They should be exactly the same.
Apr 11, 2009 | Jandy Aqualink Rs4 One Touch Control...
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
201 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
