Question about Yakima BigStack Kayak Rack Fall 2008 at Moosejaw
Is the yakima big stack safe for fiberglass kayaks
    Habit-Forming:
    New Friend:
  • 63 Answers
I Used "Vibe Kayaks Sea Ghost 130" kayak .
  • Brand: Vibe Kayak
  • Type: Sit-on-top fishing kayak
  • Weight: 74 Pounds
  • Color: Smoke Camo
  • Construction Type: EVA Foam Construction
  • Max Weight Capacity: 550 pounds
  • Material: Roto-molded single piece polyethylene
Presenting the Most Awesome vibe sea ghost 130 review
Posted on Feb 27, 2018
I used the big stack for my river kayaks and it did fine. But my fiberglass sea kayaks are so much heavier that I did not take the chance. For 1 of my kayaks I spent a lot of money to get the special sea kayak rack and it worked great. For my wife's kayak I saved some money and bought some simple v-shaped foam rubber rack attachments for $20. The foam attachments are so much easier, I don't even use the Yakima attachemnts any more. My suggestion - save your money and go with the cheap foam attachments.
Posted on Jul 20, 2009
How can I repair?
Polypro kayaks are difficult to repair. Fiberglass are easier if you can reach into the hull. Polypro repairs are done by factory using a very hot melted material similar to hot glue gun material. It may time for this one to retire if it is 'bent' and as for the 'large puncture' well, that may not be fixable.
Oct 06, 2015 | Perception Kayaks Perception Essence 17.0...
I have a van and want to carry the canoe and kayak on top at the same time. Is there a type of mountthat I can get?
Go to your local roof-rack dealer. They have all kinds of stuff designed for this. Thule and Yakima are the two biggest brand names, but there are others.
Apr 09, 2014 | Carrier Instep Cc400 Boat/canoe/kayak...
How do I install the foam blocks on my car?
It depends on the type of kit you have purchased. I'm attaching the Yakima canoe carrier instructions. If you have a different kit you may want to look on their website or get the instructions from the store you bought from. http://lib.store.yahoo.net/lib/orsracksdirect/yakima-standard-canoe-foam-blocks-installation-instructions-pdf.pdf
Jan 17, 2013 | Boating
I am getting lots of water in my tandom outfitter kayak . one hour trip produced about 3 gallons of water. how can we fix this problem leak?
Probably a crack in a seam rather than an obvious hole in the bottom. Empty the contents and submerge in water. Or conversely, fill up the kayak with water and make note of the leaks. Food coloring in the water may help to identify the area.
Fiberglass repair kits are available at the hardware store for minimal cost.
May 31, 2010 | Hobie Mirage Outfitter Kayak
What is the best way to remove oxidation from a fiberglass kayak. The color is very faded from years of direct sun exposure. Kayak is >15years old. I want to restore the original color and luster.
My kayak was nearly 30 years old & exposed to the elements all the time. To clean it up, I washed it down with the Amway Car Wash & polished with the Amway Silcon Glaze car polish.
The kayak came up beautifully & I'm still using it today
May 10, 2010 | Boating
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
May 10, 2010 | Advanced Elements Advancedframe...
Need to repair the bottom of my ocean kayak
Local hardware stores have fiberglass repair kits. Depending on how big the hole is (larger than a quarter), you might want to overlay it prior to patching. The hardware store should have a strong enough and thin enough material depending on the size.
The kits work well, just remember to let it cure for longer than required for a secure bond. My father snapped his entire canoe in half and was able to repair it and resume his trip out of the wilderness.
Sep 18, 2009 | Ocean Frenzy Sit-on-Top by Kayak - LL...
Can you fix a hole in the bottom of a kayak?
Try using a product called Marine-tex it can be purchased @ most outdoor goods stores. It is not that expensive and is a 2 part compound that is very easy to use and does not dry so fast you can't work with it. I have used it to patch aluminum boat hulls and fiberglass PWC's. Give it a try..
Jun 08, 2009 | Necky Zoar Sport Touring Kayak with Rudder...
Small crack in hobie kayak
what is the canoe made of... it may not look pretty but fiberglass will work.... you can sand and paint it later as well
Mar 26, 2009 | Hobie Mirage Outfitter Kayak
Which kayak to buy
Plastic and fiberglass are the two materials the majority of kayak manufacturers are using today. Plastic kayaks are lower priced, have the largest selection of models and are known for being tough. The down side of a plastic hull is that it doesn't hold an exact shape, it's softer (therefore slower). It's close to weighing the same as fiberglass but you can't perform field repairs on it. Fiberglass is approximately $1000 dollars more for the equivalent-length plastic boat, but the hull is much stiffer, faster through the water and you can repair it. The down side to fiberglass is that it's more expensive, and if you drop it off the top of your car, you can crack it
Dec 01, 2008 | Wilderness Systems Pungo 140 Kayak
Yakima BigStack Kayak Rack Fall 2008 at Moosejaw Logo
291 people viewed this question
Top Yakima Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Yakima Boating Expert? Answer questions, earn points and help others
