Question about Panasonic KX-T7633 Corded Phone
How to connect to headset and to use it - Panasonic KX-T7633 Corded Phone
    Champion:
  • 201 Answers
First make sure that your headset is compatible with the Panasonic phone, look at the phone left view, there is a plug hole for headset locate at bottom part. After plug in then return to phone to enable the headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
4) Press EXIT or PROG.
YBC (/\)
Posted on Oct 19, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
Blue parrot b250 xt headset instructions
Depending on the cell phone, you will need to connect to the headset AFTER pairing. Pairing just lets the phone know that the headset exists. Connecting to the headset will allow actual use. What phone are you trying to connect it to?
Feb 12, 2014 | Radio Communications
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
I am trying to pair my discovery 975 headset with my samsung intercept. i follow all the directions and my phone finds the headset but i dont get a screen asking for the passcode
dear frnd,
Discovery 975 how to pair with 2 devices
It is a 2 step process. To connect to 2 devices at a time you need to enable the feature of the headset called Multipoint, it is disabled by default.
See the pdf user guide here. Pg8 tells you how to turn on Multipoint. Pg7 tells you how to get the headset into pairing mode again for the 2nd device to search and find the headsets.
Note. At Power On the headset will connect to the most recently connected device only, so sometimes you may need to use the UI on your phones to make the connection to the headset if the headset did not connect to the device you wanted. However, if the headset did connect to one of the devices you use at power on, a short tap of the headset button will make it connect to the second device.
njoy n cheers
Dec 26, 2010 | Cell Phones
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Connecting motorola headset h350 to T-mobile motorola phone
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Nov 16, 2008 | Motorola Mobility H350 Wireless Headset
How do I set my Bluetooth Headset HBM-730 to discover mode?
4.Select HBM-730 once a connection is detected.
Tips:
Apr 20, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Panasonic KX-T7633 Corded Phone Logo
694 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
