Question about Kenmore Elite HE4 Electric Dryer
Broken handel on door. how do you remove - Kenmore Elite HE4 Electric Dryer
  • 234 Answers
You need to take the inner frame of the door off to get to the handle. i know it's a long process but we can thank the engineers for doing that.
Good luck my friend :)
Posted on Jul 18, 2009
  • Ned Halaweh
    Ned Halaweh Jul 18, 2009
    you need to take the inner frame of the door off to get to the handle. i know it's a long process but we can thank the engineers for doing that.
Replacing exterior rear door handle
Before removing the door panal remove both door handel and unlocklatch check for any crews near speaker then try from a corner
Apr 04, 2014 | 2007 Opel Antara 2.0
How do you get the door panel off a 1988 Cadillac Fleetwood D'Elegence?
Disconnect negative battery terminal. Pull out inside door handel,then remove screws from behind it then pry out the door handel bezel.Pry upwards and out on the armrest switch control plate and disconnect electrical connections.Remove the door panel screws through the armrest opening .remove the screws from under the door pull handel as well.Pry out the interiory lamps mounted in the ends of the armrest and remove the panel screws from behind it. Also make sure there are no lamps hidden from view like under the armrest if so pry out lamp and remove panel screws from under it.Next start at the bottom of the door and trim panel and pry out each retaining clip. Clips are approximately 8 inches apart.Once all of the clips and screws are removed from the door panel it can be removed by gently lifting up and out on door panel.Ihope you find this helpfull,good luck.
Dec 06, 2010 | 1988 Cadillac Fleetwood
I have a 2000 Lincoln Town Car that the passenger window will not go down. I have power at the switch but can't figure out how to take off door panel to access motor to test.
FIRST REMOVE THE DOOR LOCK OPERATING KNOB , SLIDE OUT THE SPACER BEHIND THE REGULATOR HANDEL AND REMOVE THE HANDEL FROM THE SPLINES , UNCLIP THE TRIM COVER FROM THE DOOR AND REMOVE IT FROM DOOR , UNSCREW DOOR HANDEL SCREWS, LEVER BETWEEN THE DOOR TRIM PANEL AND THE DOOR TO RELEASE THE TRIM PANEL STUDS.
Nov 01, 2009 | 2000 Lincoln Town Car
Driver side door wont open.solution on opening the door
This is usually caused by a broke plastic retaining clip.the inside handel should have a insert covering a screw pop out the insert and remove the screw. If there is no rod atached to the handel (broke clip) locate the rod in the door (a metal coat hanger works good) pull on the rod towards the front of the door and it should open.Replace the clip or sometimes the handel itself breaks needing replaced.
Hope you get a handel on it!!
Oct 23, 2009 | 1993 Honda Accord
Need to remove the driver's side inner door panel to replace the door lock due to vandalism of the lock
CLIP OFF COVER ON DOOR HANDEL /REMOVE BOLTS FROM HOLES IN HANDEL/ PUSH UP ON PLASTIC RING ON WINDOW WINDER NOW PRISE OPEN DOOR PANEL FROM DOOR.
Oct 21, 2009 | 2005 Ford F 250 Super Duty
BROKEN REAR DOOR HANDEL AN WINDOW WONT GO DOWN!
using small hook tools and tack pullers shaped like mini wonder bars, you can remove the door panel. once removed, you can fish around on the bottom middle of the door and pull the cable to unlatch the door.
Apr 14, 2009 | 2001 Toyota Sequoia
Broken door handle
The fresh food door handle is part number is 218668401 and the freezer dor handel is part number is 218668401 same number. Visit my web page and enter your refrigerator model number WRS6R3EW1 or mthe door handel number
218668401 in the model or part search feature. Below is the like to my web page. (Click on link below)
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Mar 26, 2009 | Refrigerators
Door handel broken.(inside)is this a hard fix? for most.
easy fix , just remove inside door cover, and install new handle, but handle broke because of bad hendge bushings making door hard to open, driver side ususlly first to brake then passenger door a year later. need body shop to replace door bushings
Feb 24, 2009 | 1995 GMC Yukon
How to repair Suzuki Forenza interior driver's door handle?
you answered your own question,ease the door panel with two screwdrivers ,one either side of the plastic clip and watch for the mastic
Jan 23, 2009 | 2005 Suzuki Forenza
DRIVERS SIDE DOOR WILL NOT OPEN WITH OUTSIDE DOOR HANDEL?
Broken linkage connecter at handle or latch, you have to remove the door panel for access. It is possible the actaul handle is broken where the linkage attaches.
Dec 26, 2008 | 1998 Chevrolet K1500
Kenmore Elite HE4 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
