Hello! i need to add my laptop to my router but i think i got confused when i entered the i.p address so now my desk top has the same i.p address and i don't know how to fix the promble.can you help me?
  • 400 Answers
You can also reset the router by removing the power cable for about half and hour or by pressing the reset switch at the back(if it has one).
Make sure all computers have automatic IP address ,this can be changed in Network Connections section of windows by right clicking your network connection ,select properties then select tcp/ip and make sure ip address is automatic.
Posted on Jul 16, 2009
    President:
  • 1,383 Answers
Access your router with this link
http://192.168.1.1 or
http://192.168.0.1
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password"
then go to dhcp option and enabled it .
Then save settingsd then restart .
Then all your computer which are network with router is get ip automatic.
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
My HP configuration says there is no IP address and cannot find the network even though it lists NETGEAR on my HP. I cannot print from my desk top or my laptop. I know the router(?) works because I have...
when you run the wireless setup wizard .. after it searches the network , it will ask for the WEP key or WPA key.. you need to enter the key correctly and that key is also case sensitive .. so enter that key carefully.. after it gets connected then run the installation or run the add a device option which comes in the installation cd..
check if it works..
Oct 30, 2009 | HP Photosmart C6100 All-In-One Printer
Linksys router will not work with my hp deskto
you will need to "set up" the router.
http://www.linksysbycisco.com/US/en/support
This is the support page for linksys, if you enter your model in the drop down box, you may see a "Easy Setup' or "assistant" software to help set it up, otherwise you can contact your ISP and they will walk you through entering the right settings.
You will usually have to enter 192.168.1.0, or something close in the address bar when you hook your router up and get pagecannot be displayed, type in that number (or the correct ip of the router) and it will get you to the router setup page.
Apr 11, 2009 | HP Pavilion a1330n PC Desktop
I have two laptops and a desk top computer. I
Is it a wireless router?
from each laptop: at the Browser Address Bar in Internet Explorer type 192.168.0.1..enter
this will let you know if you are talking to the router.
Mar 13, 2009 | Office Equipment & Supplies
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
Jeff
May 04, 2008 | Computers & Internet
My husband unplugged my router from the DSL box. I have been messing around with it but don't remember how to add my router. I know it sounds simple but I'm lost. I fixed the connection to the DSL box...
most router normally have one or two WAN connection port and one LAN connection port.
if you are connecting your desktop with the available LAN port then you need a hub or switch to create multiple connection .
alternatively if your router have two LAN port make sure you are using the right ip address and the proper gateway address(from your isp)
Apr 20, 2008 | Computers & Internet
Router installation
simply connect your laptop to the router using the supplied lan RJ45 cable and then open up your web browser and type in the address bar 192.168.2.1, this will take you to the router password page, just press enter as by default there is no password.
The next page will show all the menus on the left, select connection wizard and enter your isp password, username and settings.
Nov 03, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
