Question about Tunturi T30 Treadmill
Tunturi j440 the console is not lit up when switched on and nothing is happening,checked the plug etc.
    Problem Solver:
  • 9 Answers
Try turning the switch off then on while plugged in to reset the electronics.
Posted on Oct 22, 2009
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Control buttons have stopped working
You'll find the battery acid has leaked on the green cable linking the console to the buttons. I wiped down this green cable with water - removing the acid residue and the buttons started working again.
You can get to this cable by unscrewing the plastic fascia. There are six screws on the rear and two on the base of the unit.
Seb
May 27, 2013 | Tunturi R60 Rower
Won't start
Check alternator fuse , it's should be a high amp fuse . Question is did you give some one a jumb start , this could happen , another thing to check is your ignition fuse and your ignition switch , but first check all fuses . Including the big once under the hood and inside the car . Good luck and I hope this helps
Jan 15, 2013 | Cars & Trucks
Tunturi e430 bike not switching on
Verify the power cord end is the correct size and polarity. It should be marked on supply and should be marked on the housing near where it plugs in. If those are correct, check the fuse inside.
Jan 24, 2012 | Exercise & Fitness
Turned off after playing, came back the next day and nothing happened. Wouldn't turn on, no lights etc. tried pulling plugs and reconnecting and still nothing. Tried the reset button, still nothing....
Hello
Possible the outlet its plugged into is bad or a blown breaker.Try plugging in something else like a lamp to make sure.
Another problem could be the power supply to the wii is no good.
Oct 09, 2011 | Nintendo Wii Console
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be...
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Nov 10, 2010 | Music
The Wii console will not turn on. What could be the problem? I have tried plugging into diff outlets and nothing.
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in theowners manual FAQ, considering it happens almost every time there is apower surge or the power goes out, etc.
Even if it's hooked upto asurge protector, this happens. Power comes back on, but the Wii appearsdead. It won't turn on, and the LED indicators won't light. If therewas a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter2_bing.gif,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surgeprotector outlet. Don't unlpug it from the Wii, it has to be at theoutlet. You have to kill power to the adapter.
Unlpug it fromthe wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuittime to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
My daughters dsi is on, but wont turn off. The
Hold the power button some time, the system must turn off.
Oct 06, 2009 | Nintendo DS Lite Console
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
Tunturi T30 Treadmill Logo
343 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
