Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by mobile or a desktop to see the search box. Mobile view has no search box.}
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Is it a LCD type screen? If it is, look close, is there no backlight, or its lit with no image? If its no backlight, the screen backlight inverter is bad. If there's backlight with no image, can be the display, connection cable or mainboard.
Yes...My 50inch plasma is mounted on the wall; has been for four years. You must be sure to screw the bolts for the wall mount which will suppport the TV are in the middle of the studs. you can get a cheap stud finder at home depot from under $10.00. It's usually only four bolts to screw into the studs and you're set.
