Question about Refrigerators
When power is applied to the Fridge (Sub Zero, Mod UC-24R) the light inside will illuminate for 10 seconds, then turn off, the controll pane will not power up, the power button is pushed but no responce or illumination of the panel
  • chiefengi332 Jul 16, 2009
    The Fridge does not operate at all, the Breaker was checked OK, power at the receptacle is correct aswell. when the fridge is provided with power, the door light will illuminate momentarally (10 Seconds) then turn off untill power is removed and restored again.
    the control panel is at the bottom the fridge and there is only one switch I can see at the bottom (for the door).
    The control panel is inoperable.
    Thanks for the Help, I tested the circuitboard and a voltage was present coming in, Iv'e got a new one on order now. Cheers
  • 3,037 Answers
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free as this is a somewhat common problem. Let me know how this turns out.
Benjamin
Posted on Jul 16, 2009
  • Benjamin Patri
    Benjamin Patri Jul 16, 2009
    If the control panel is getting power, then it is most likely the problem with all of the symptoms that you suggest. You can get a new one from Repair Clinic, If replacing it doesn't work, then you can return it within 30 days. Click on the following link for finding your control board or call 1-800-269-2609
    http://www.repairclinic.com/Sub-Zero-Ref...
    Benjamin
My sub zero 600 series has no light in fridge nor on control panel
There will be two switches per compartment, one is the fan switch, the other is for the lights... Remove the top compartment vent panel, the switches will be accessed from above... remove the wires and push them down into the fridge... you can test them by setting a meter to "continuity" test and pressing the paddle of the switch to see if it lets current through.
SUB-ZERO machines are more serial number dependent when ordering parts... http://www.midwestdistributing.com/Store/OpenPages/ManualPage.aspx?PageTitle=MANUALS
Aug 20, 2016 | Sub-Zero 632 / S
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 650/s control board light is out and inside lights out but fridge works.
On this model, the lights work with the light switch, if it stick all the light in that section will not work. Parts number 7014646 (about 20 bucks) If only the control display is not illuminated then the bulb behind the control is the only problem.
I hope this helps.
Oct 02, 2013 | Sub-Zero 650 / O Bottom Freezer...
Pro48 sub zero clicking
This usually indicates that the control module is bad. Trace the clicking to it's source either on the back of the fridge or inside the fridge near the controls.
Feb 29, 2012 | Sub-Zero PRO 48 Side by Side Refrigerator
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero fridge doesnt turn off
If your temperatures are OK, then you have a bad thermostat control.
Feb 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
