Question about Kenmore 63942 Dryer
My dyer does not get hot.
When you turn it on it starts to get hot for able a minute or two then you hear a click and that is when it just blows cold air.
  • wirenuts81 May 11, 2010
    if its not your high-temp thermostat...it is probably the thermal coupling...this is two pieces one is connected to your heating element on the outside..and the backup piece is above it on the same housing as the heating element
    Genius:
  • 1,122 Answers
Change your high temp thermostat,remove back panel and it's on your right bottom of box-mike
Posted on Jul 17, 2009
When I start my grand marquis 2003, I will turn on the ac and I will hear a click. Then like thirty seconds later I will hear another click. My problem is that my ac blows hot then I hear a click and it...
The a/c compressor is cycling on/off this will happen when low on refrigerant or not enough air flow across evaporator 1st check system by rolling windows down place blower fan on highest setting hold throttle just above a idle 1200-1500 rpm"s if still cycling then open hood and find a black can it could be silver at firewall is the pipe coming from inside the car cold about 45 degrees if not system is low. if cold check cabin air filter it is pulled if equipped
May 09, 2014 | Cars & Trucks
Ac
You would need to find out if the compressor continues to run when the cold air stops.
Jul 17, 2013 | 2000 GMC Sierra
I have a 94 lincoln town car and my heat wont work i hear a clicking noise in the dash
THER SHOULD BE A BLEND AIR MOTOR UNERD DASH THAT CONTROLS HOT AND COLD SOUNDS LIKE THE GEAR IS STRIPED OUT ,NOT EASY JOB TO DO
Dec 15, 2011 | 1994 Lincoln Town Car
Dyer only blows cold air
U may have a blown thermostat or bad heating element.
Nov 14, 2011 | Dryers
The hot and cold selector switch on the heater doesent function
That part of the needs to come apart to see what is wrong.
Apr 10, 2010 | 2004 Ford Explorer
A/C air sometimes cold, sometimes not on VW Beetle 2001 Turbo
AC will not work with temps are cold even when it is turned on. The air is colder cause the temp is colder. The AC cycles in hot weather because the AC charge is low and needs recharging. You will know this if you open the hood run the AC and you will hear the clicking sound of the AC compressor magnetic clutch. You can recharge it easily buy buying a compatible can of refrigerant. I suggest buying the kit with the gage so you don't overcharge the system which will cause freeze ups
Jul 03, 2009 | 2001 Volkswagen Beetle
Ac blows hot
That sounds like the Blend Door Actulator has decided to go loopy. I heard of people turning it to hot and getting cold, Normally when this bit goes it makes a click click noise
Jan 20, 2009 | 2000 Lincoln Navigator
A/c blows cold then goes to hot air
sounds like a vaccum diaphram may be leaking try listening for hissing noises under dash near the glove box,set blower to lowest setting\off if you can and still have a\c on.
Oct 07, 2008 | 1995 Volvo 850
Kenmore 63942 Dryer Logo
245 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
