Question about Asrock P4I45GV R5 Motherboard
No Beep sound during startup. Motherboard or Processor ?
No beep,No Display on my monitor,only CPU heatsink fan is moving
    Problem Solver:
  • 10 Answers
Your on board atx smps connector is faulty, replace it..
Posted on Aug 13, 2009
    President:
  • 1,383 Answers
Ok
pull cmos cell for 15 minute then check so all settings of bios are reset.
Also Refix RAM memory reattach all connection to motherbord.
Posted on Jul 16, 2009
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
CPU Heatsink is cool but fan runs fine no display
No beep or sound means Motherboard Defective, aside from Processors is OK, Memory is OK, and the rest!
Buy a new one not as the same Motherboard you use. ASROCK Motherboard are have a a problem when high temperature occur.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 29, 2009 | Asrock P4I45GV R5 Motherboard
Monitor black after cpu turned on
This can be any number of things wrong. Does the computer make any beep sounds when it starts?
If there is one, quick "BEEP" sound, than all is well, any more than one BEEP sound means trouble.
However, a computer screen going black like that can be a memory module has failed, or the video card, (if there is one), and it could also be a system fan going bad. Computers are designed to shut themselves off to prevent damaging the processor, and motherboard, if there is a bad fan, video card, or bad RAM. If you can take the side of the computer off, and start it up, try to notice if the fans, and hard drives power up. If they do, than you can move on to the RAM modules. RAM is harder to troubleshoot because if it is bad, the only way to find out is to replace it with known, good RAM. Or, if you have heard BEEP CODES at the start up, than you can search on the internet under "Beep Codes" and see if you can find out what the codes mean. If you are not comfortable with any of this, than you will have to find someone who is, and pay them to fix it.
May 22, 2009 | Westinghouse L2046NV Monitor
Asus p4s533 will not boot after replacing fan + heatsink
Try to remove the processor, then clear it with contact cleaner, then plugin it again..
There isn't beep : Processor, and long beep is memory..
Hopefully this be of some help/idea..
Nov 25, 2008 | ASUS P4S533-MX Motherboard
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
try to clean your video card and ram using the eraser.
Mar 17, 2008 | ASUS P4VP-MX Motherboard
Asrock P4I45GV R5 Motherboard Logo
558 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
