Safe International Cobalt Em-015 Fireproof Safe Digital Electronic Lock Logo
M
Missi Posted on Mar 17, 2016
How to reset combination - Safe International Cobalt Em-015 Fireproof Safe Digital Electronic Lock
How do I reset REI Double cable lock
  1. Locate the reset button, which is usually a small button or lever located near the combination dials.
  2. Press and hold the reset button while turning the dials to set your new combination. Make sure to remember this new combination!
  3. Release the reset button and test the new combination to make sure it works.
Please note that the specific location and method for resetting the combination may vary depending on the specific model of REI Double Cable Lock you have.
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Resetting combination on Paragon 7875 Depository Safe?
To reset the combination on the Paragon 7875 Digital Keypad Depository Safe, you will need to locate the reset button on the back of the safe. Once you have located the reset button, press and hold it for 3 seconds. This will reset the combination to the factory default of 0000. You can then enter a new combination of your choice.
1helpful
How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
1helpful
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
2helpful
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
How to set Samsonite combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
17helpful
3answers
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Top Safe International Home Security Experts
ZJ Limited
ZJ Limited
john h
Larry Ng
Larry Ng
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
