Question about Husqvarna Garden
Husqvarna ct 135 mower,when attempting to engage cutters with lever beside steering wheel the alarm sounds and then the engine cuts out
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Posted on Jul 16, 2009
Blades wont engage
Hi Mary:
The drive belt will possibly have slipped off a pulley.
With the engine OFF, look between the cutting deck and the underside of the machine. Check the position of the belt as you have a helper move the engage/dis-engage lever back and forth.
Reply as a COMMENT to this post if you need more assistance.
Cheers
Mar 28, 2016 | Husqvarna Riding Lawn Mower 42 Inch Cut...
While mowing the blades disengage and engage ?
your battery might be going bad if the unit has an electric PTO clutch
Nov 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Husqvarna Proflex 21 just stopped engaging the blades after bump over brick. Was working fine, on starting the next cut the engine goes well, lever works but no mower blades turn when lever lowered. T
Sounds like you have broken a shear pin in the drive pulley.
Shear pins are made to break if you hit something. Other wise it would cost a lot of money to repair the damage.
Jan 24, 2015 | Husqvarna Garden
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
My mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
May 23, 2009 | Garden
TURNING RIGHT ENGINE WANT TO CUT OUT
sounds like the operator presence control switch needs adjusting.
Under seat.
Apr 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
611 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
