Question about HP LaserJet 3030 All-In-One Printer
When the paper comes out of our HP3380 all in one printer/copier/scanner/fax a black line appears on the ledt side of the paper.
    President:
  • HP Master
  • 1,447 Answers
It is the problem your copier cartridge unite change it then solve your problem
Posted on Jul 16, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Thick line when goes throught auto feeder
The automatic feeder passes the page over the scanner, the scanner does move, so even a small mark (often find it is correction fluid) will effect the whole page, check the glass on the left side of the scanner for any sort of mark
Sep 08, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Jan 30, 2009 | HP J4680 Office Jet All-In-One Printer
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This...
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
