Question about Karcher 2500 PSI Pressure Washer
Gas tank leaks, raw gas out the exhaust
My gas tank leaks and upon starting the engine raw gas blows out the exhaust. Carb float valve sticking and draining gas into intake manifold?
  • 174 Answers
Get the leak fixed
Posted on Jul 19, 2009
I have a 1984 jeep cherokee pioneer 2.5 l.engine that has 360,000 miles on it. Almost immediately after I change the oil it reeks of gas. What are possible reasons behind this and how can it be fixed?
it's a carb engine and carb fuel pump.
redux for "IT"
OR DID "IT" MEAN THE OIL STINKS OF GAS.
NOT CLEAR.
i drained the oil and the catch pan stinks of raw fuel.
THE GAS DILUTED WITH GAS, CAN BE 2 THINGS.
ON CARB CARS.
1: THE BLOCK MOUNTED FUEL PUMP is bad and leaks fuel into the crankcase, badly and fast.'
2: carb float valve is stuck, open and fuel flowing like crazy out all jets and nozzles , un controlled...
84 XJ Pioneer. AMC 2.5L
not to many of these left on the road.
it had a Rochester or Carter CARB.
Ever check float levels on it?
or rebuild a carb? with new float valve, that does not stick?
take off air cleaner
stall engine, at same moment look down carb bore
(horn) does it still leak fuel engine off?
oops. (float stuck)
if not, then jump on fuel pump bad inside. replace it.
May 26, 2016 | Jeep Cars & Trucks
After cleaning carb, I now have raw gas coming out the exhaust???
Hi, Barry and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
Good luck and have nice a day.
Oct 26, 2015 | GAS Motorcycles
What is problem with my john deere lt 133 mower it has gas in the oil?
What engine do you have (Briggs, Kohler..etc) and what is the model number on the ENGINE..not the model number on the body?
Jul 19, 2014 | John Deere Garden
Engine starts then backfires and sometimes leaks gas on exhaust
IS it leaking gas on the exhaust or thru the exhaust. I have seen the float in the carb stick in the down or fill position and flood thru the exhaust.
Sep 04, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Gas is leaking from behind front section of chain. what's back there that could be leaking and how do i fix it
Probably carbs overlowing, overflow pipes from the carburettor-s will hang out from below the engine, thus if the float valve sticks in the carb the fuel will overflow away from hot exhaust, you will have to follow pipe up to the offending carb remove float bowl and inspect and clean float valve, you will have to remove float and inspect the valve and its seating for dirt or varnishing which is caused when fuel is left for a prolonged time within the carb
Feb 26, 2011 | kawasaki Ninja 250R Motorcycles
The unit just started burning oil like crazy on start up. Tons of white smoke and oil coming out of the exhaust. Its a 4 stroke motor so im not sure what the problem is. Any help??
Remove the Oil Breather from the side of the engine near the base of the valves and clean it with both engine degreaser and carb cleaner. If the reed assy sticks on the breather the crank case will over pressurize and port oil into the breather. Also if the engine was over-serviced with oil it will present the symptom you describe. Sometimes a carb problem will allow fuel to leak into the crank case after sitting for a long time and the oil will have gas in the oil. Sniff check the oil. If it smells like gas you may also have a sticking carb float or float needle.
If you need more assistance just repsond here and I will help you.
Thanks for choosing FixYa, Kelly
Jan 26, 2011 | Honda Garden
Gasoline leaks thru the air filter when you open the valve from the gas tank to the carb.
I think the float in the carb is sticking. Tap on the carb a few times and then try it. You may have to rebuild the carb.
Oct 25, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Engine pumps raw gas out of the carb under power
NEED TO KNOW WHAT KIND OF ENGINE. DOES IT HAVE A PUMP? IS IT GRAVITY FEED? IS THE CARB AND GAS TANK ONE PIECE? IT SOUNDS LIKE FLOAT IS STUCK OR FLOAT BOWL GASKET BAD. COULD BE ALOT OF THINGS. NEED ENGINE MODEL OR NAME ON COVER.
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Fuel in the crankcase
Your float valve is sticking - the carb fills up, the fuel runs out through the carb into the engine.
Get a new float valve, until then - turn the fuel off at night.
Jul 01, 2009 | 1988 Suzuki DR 750 S
Karcher 2500 PSI Pressure Washer Logo
550 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
