Question about Logitech Trackman Wheel 904353-0403 Trackball
Trackball interference with another in close proximatey
  • 118 Answers
Use an usb extension (not a hub) to get farther away from other interfering track ball.
Posted on Jul 17, 2009
2002 Hyundai Elantra 2.0, #1 & 2 cylinders misfires, spark plugs are good, compression 145 PSI, #1 & 2 Injector not firing, I switched injectors with 3 & 4, & they are working. Vehicle...
If it is only that circuit and not the parts itself, it is likely that either someone has damaged the wires going to the ECM to drive the injectors or the ECM has failed on those 2 drivers. My suspicion is that this happened shortly after the install. Find where the wires are for the device itself and see if they are in close proximatey to any wiring harnesses or has been cut. This is where you will likely find the culprit.
May 06, 2011 | Hyundai Motor 2002 Elantra
Logitech trackman wheel stopped working. I have changed the batteries and reset, but the problem persists. Can you help?Thank you, Claudia
First step would be to clean the sensor inside the ball housing. Remove the ball (turn retaining ring on bottom or simply pull out) and clean the sensor area free of debris or dust using cotton swabs or klenex. Next step would be to ensure that you have have no wireless devices such as a cordless phone or wireless routers in close proximity that may interfere with the signal. Finally, test on another computer to see if you gain functionality else it may be time to find a new mouse.
May 04, 2011 | Logitech Cordless TrackMan Wheel...
After months of good work my mouse stopped working, it has to be very close to the receiver for the pointer to move. New bateries installed, still the same.
Has any new piece of hardware been put in between the trackball and the receiver? Electro-magnetic fields can cause interference. I had a similar problem once - didn't even unplug the receiver, just moved it behind the monitor. It was a big clunky CRT screen and created a huge EM field - huge enough to cause interference with the trackball.
Oct 05, 2010 | Logitech Cordless TrackMan Optical...
My instrument cluster oil pressure,rpm and kilometers only are not working.i was checked all fuses and all related wiring circuit ok.
there is a 5 volt regulator that supplys power to the gages. it is located on the instrument cluster or in close proximatey. you'll have to locate it, find the part number, obtain one at an electronics store, de-solder the old one and solder in the new one
May 25, 2010 | 1993 Toyota Land Cruiser
Trackball not functioning
if ur trackball doesnt work because its dirty theres a perfect way to clean it. my trackball get dirty all the time from greay hands and once that trackball starts to feel buttery and greasy its not going to work (usually a htc snap trackball feels rough and vibratety when you scroll with it). I'm not sure if htc trackballs come out so it sort of scratch the trackball with my fingernail, this scratches the grease of until if feels rough again. if the trackball moves around to much when you clean it, press it in with the other fingernail. if this doesnt work i guess you could get some rubbing alcholon a cotton ear bud (q-tip) and clean it but i havent tried this. if a greast trackball is the not the problem to your malfunctioning then i guess you should get a new trackball or get it repaired in a shop. :D
Feb 26, 2010 | HTC Snap S522 Cell Phone
Were do i put a memory card into the sidekick 3
if you take the back off the sidekick..holding the phone the way you would to flip it open..the side that the trackball is on the slot is on the other side of the trackball its a small slot so look very closely
Aug 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Interference with receiver
use an usb extension (not a hub) to get farther away from other interfering track ball.
Jul 16, 2009 | Logitech Cordless TrackMan Optical...
Unable to save to contacts folder and unable to copy from sim to contacts folder, pls help my contacts folder is empty and i can't save nor copy to it. using bold 9000.
To add your SIM contacts to your BlackBerry Address Book.
1. Press the 'Menu' key.
2. Highlight 'Contacts' and select (press the trackball).
3. Press the 'Menu' key.
4. Highlight 'SIM Phone Book' and select (press the trackball).
5. Press the 'Menu' key.
6. Highlight 'Copy All to Contacts' and select (press the trackball).
To add your Black Berry Address Book contacts to your SIM.
3. Highlight the contact you wish to move and press the trackball.
4. Highlight the number and then press the trackball.
6. Highlight 'Copy to SIM Phone B...' and press the trackball.
7. Press the trackball and highlight save and press the trackball again.
hopes it helps better.
Jun 12, 2009 | RIM BlackBerry Bold Smartphone
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
TrackMan Wheel Trackball Spring - where does it go.
it's not really a spring -- it's just a twisted piece of wire. actually, it's what makes your little scroll wheel click when you turn it. place the scrool wheel in the little plastic bracket that holds it with the longest piece of axel (hollow side of wheel) in. then TURN THE BRACKET OVER. the wire goes on the BOTTOM, which is quite counterintuitive. you'll see how it goes -- the smallest end of the wire goes INSIDE the scroll wheel and the kinda squared end of the wire goes into a little hole in the bracket. you'll understand when you look closely at it. once the wire is installed, hold it in place when you turn the bracket/ball/wire assembly over. fit the legs on the bracket into the groves on the base of the trackball -- that's the side where the ball sits and the circuit board is. make sure the scroll wheel passes through the trackball cover when putting it all back together. VOILA! problem solved.
Jun 02, 2008 | Logitech Cordless TrackMan Optical...
Logitech Trackman Wheel 904353-0403 Trackball Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
