Garden Logo
J
Jim McMillan Posted on Mar 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need Drive Shaft for JD 317 with 17hp Kohler engine, 1981 year bought
Richard Schanie
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Expert 242 Answers
  • Posted on Mar 17, 2016
 Richard Schanie
Expert
Level 2:
Dedicated:
Answers
242
Questions
0
Helped
90973
Points
920
The I had I just replaced the U Joints in it. But yours might have been let go to long and tore up the ends . You can buy them new on ebay link attached. Has some good picture JOHN DEERE OEM UNIVERSAL DRIVE SHAFT AM37875 317
1helpful
K300 gas engine. What is output shaft dia and is it keyed?
3/4 Keyed Shaft ' eBay
www.ebay.com/bhp/3-4-keyed-shaft
eBay3/4" Dia. Steel Shaft / Rod 18" Long. ( Keyed 3/16 "both ends ). $34.21 .... 3/4" to 1" inch w/Step Key Gas Engine pulley Crank Shaft Sleeve adapter Predator.
Vertical shaft Kohler Engines - Engine4Less.com
engine4less.com/ALL-Vertical-shaft-Kohler-Engines/
This engine has same mounting and shaft as all KOHLER Single cylinder ... 1"diameter x 3-5/32" length keyed VERTICAL (UP and DOWN ' ) crankshaft. Please ...
Just wondering what the year of my John Deere 400 is serial number C400J123028M. It has the 20 HP Kohler motor in it.
JD 400 Garden tractors were made from 1975 - 1983.
Serial Numbers
1975: 30001
1976: 55001
1977: 70001
1978: 80001
1979: 95001
1980: 120001
1981: 155001
1982: 190001
Go to this site and you may be able to track it down.
John Deere 400 attachments
http://www.tractordata.com/lawn-tractors/000/0/4/41-john-deere-400-attachments.html
Be sure to read this discussion on serial numbers.
Tractor serial numbers
"Find the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers."
Change gear oil 1981
Drain is on the bottom of the drive shaft. Fill is on the side of the drive shaft. Fill the shaft drive assembly to the bottom of the threads of the fill hole. Takes about 200-300ml.
Is it possible to replace my Kohler Command CV491S with a Kohler Command PRO CV620?
technically it is possible to do a heart trnasplant
all you need to check are the mounting flange holes or be able to drill new holes in the mower frame
and next the method of attaching the drive pulley or pto to the crank shaft has to be considered
Jul 03, 2017 • Garden
1helpful
Cylinder head torque 1n diesel engine
Hi!
The Toyota Starlet is a fuel efficient compact car that replaced Toyota's Publica model in 1973 and was manufactured through the 1999 model year. The Starlet was sold new in the United States for only four years, from 1981 through the 1984 model year. Originally a rear-wheel drive car, the Starlet transitioned to front-wheel drive in 1984.
The 1981 to 1984 versions of the Starlet that were sold in the U.S. were powered by a 1.3 liter OHV engine with four cylinders and electronic fuel injection. The engine has a 2.95-inch bore and 2.87-inch stroke and produces 58 horsepower at 4,200 rpm. The 1981 and 1982 versions of the engine produced 67 ft-lbs of torque, and the 1983 and 1984 versions produced 74 ft-lbs of torque. The compression ratio is 9.5:1.
Hope that helps!!
EJ Kudelka
1helpful
JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
1981 550 to 650 engine swap
the only thing you could possibly do is change out your swing arm off the 650 and put it on the 550 but you may also have to change out the wiring harness as well to get the 650 running properly
Top Garden Experts
Jay Finke
Jay Finke
john h
