Friends son moved jumpers and turned all switches 1-10 off .I want to restore back to factory settings.
ASUS P4B with Pentium 4
  • 205 Answers
Go to the ASUS website. You should be able to find the documentation on this motherboard which will tell you all the default settings.
Posted on Nov 18, 2007
CPU compatibility issues
the cpu test is something a computer does to test the board. it sounds like there is something wronge with it. pentium 4 boards very with the clock speed. it depends on the age and if it can handle. if you went from a 1.7 to a 3.2 than you might be overloading it not allowing the computer to register.
basiclly what you need to do is get you a board that is already set-up for a 3.0ghz or higher proseccor.
even through it is a p4b some of the older models can only be upgraded to a 2.0ghz.
Aug 12, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
I have pentium 4 processor & 845 GZD chipset from last one month my LCD 19 is not displaying with this board but 15 TFT monitor is OK with that so can i know how to solve this
most likely the monitor receives a signal/resolution it can't accept. Try to boot in the BIOS - if it's the same then the monitor itself is defective and you must take it to be repaired.
Oct 01, 2010 | ASUS Intel 845 Chipset P4B (P4B WOA)...
ASUS LGA775 mother board
1.Power down your PC.
2.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
3.Find the 3-pin jumper near the power supply, typically labeled "clear cmos" or "reset bios".
4.Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
5.Replace the jumper to connect the 2nd and 3rd pins.
6.Push the power button on the front of your PC once.
7.Wait a minute.
8.Return the jumper to its default position, connecting the 1st and 2nd pins.
9.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
10.Power on your PC with its front power button.
If it doesn't work go to alternate options
Alternate Method
1.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
2.Remove the CMOS battery. This should be a regular 3V, round, flat watch battery.
3.Wait at least 5 minutes.
4.Reinsert the CMOS battery.
5.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
6.Power on your PC with its front power button.
Alternate Method
1.Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10.
2.Go to the last tab or page of your BIOS.
3.Select an option similar to "restore factory settings".
4.Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Nov 21, 2009 | Computers & Internet
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
Forgotten password ASUS P4P800-VM
There is a blue jumper located just below the lithium battery on the motherboard. You need to remove the jumper and move it to the two pins on the right for about 10 seconds to clear the CMOS then move the jumper back to where you found it. That should clear out the password. It will also change all the BIOS settings back to factory so adjustments to the BIOS may need to be made after reset.
Sep 06, 2009 | ASUS P4P800-VM Motherboard
Graphics card problem
Your motherboard uses AGP for graphics card. Here's a link for full specs:
Jun 10, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Can I use Pentium 4, frequency 3.0 GHz with Asus P4B?
Asus support says the fastest CPU you can use in that MB is a P4 2.6 GHz or a Celeron 2.8 GHz.
For the P4 you need BIOS ver. 1011 and for the Celeron you need ver. 1013.004.
Here is a link to the entire list:
P4B CPU Support
Thanks for using Fixya.
Apr 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Can I use Pentium 3 GHz with Asus P4B?
no, you cannot, cpu socket on pentium3 is not the same, as pentium4
Could not detect HDD on my Asus P4B-M Motherboard
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Computers & Internet Logo
469 people viewed this question
David Payne
David Payne
